Does Minix Neo G4 still have the best stock firmware? Does the new stock firmware have any issues?
Is the device still supported by Minix?
Is their good custom firmware for it? Will that firmware have issues?
If I update can I still use Netflix?
Will I have any problems using the Mele F10 Pro with it?
Are their any problems using a USB Ethernet Adapter with it? Witch one should get?
Are their any problems watching video files from a USB Flash Drive?
Is it better to have Tronsmart MK808 or Rikomagic MK802IIIS Instead?
