MK918: New SUPER 1080p Best Stock KitKat 4.4.2 (570 MB) Regular downloadi link Google APPS included !!
    I am trying to collect all noobs need in one Thread
    So Let's start :
    1- Rockchip Batch Tool v1.7 (with Rockusb Driver v3.5, Windows x86,x64 (Vista,7,8)) Worked Great with me
    Here : http://dfiles.eu/files/od97te8er
    2- Latest Official stock Android 4.4.2 KitKat beta Release in a regular downloading link,
    Here : http://dfiles.eu/files/v19660ole
    I have just flashed it & It Works GREAT !!
    ** Just had to disable the hardware keyboard which was enabled by default, I use only a mouse & remote to get the soft keyboard ON
    Screenshots :
      Re: MK918: New SUPER 1080p Best Stuck KitKat 4.4.2 (570 MB) Regular downloadi link Google APPS included !!
      sorry, wrong and wrong
      understanding that no custom roms
      Enviado desde mi GT-S5830 usando Tapatalk 2
        Originally posted by eduaveoso View Post
        The Only wrong thing here is your reply !
        Who said it is a custom ROM ??
          OTHER HOSTER PLS!
          All enjoy my FREE FULLSPEED LINKS part1 and part2
            Flashed this on my mk802iv with new wifi.
            i rooted it using kingo app.
            I removed the nav bar completely by editing build.prop
            qemu.hw.mainkeys=1
            everything is working fine for me, but 1 gb app space is not enough.
            also i can't control volume using my wireless keyboard as on other roms. when i try to turn the volume down it mutes the device.
            Also some issues with cheapcast.
            wifi is stable and fast
            didn't test bluetooth
            i had choppy online streams on other roms but this one fixed the problem. it is good.
            just need to fix the app storage space.
              qemu.hw.mainkeys=1
              Use KK parametar files from Finless KK for 6210 beta 2 rom..there is 1,2,4,6 g parametar files...
                This is a older build of 4.4.0 rather then the updated 4.4.2 which certainly explains the volume issues.
                Mk802IV Neomode 1.9a original rom 720p
                  I dont know how to use these files ... I used the stock batch tool to flash
                    In Finless rom you have rom flash tool, 1.37 I think...on this forum exist at least two or three thread with explanation...you just have little to commit to it...
                      Its kinds of pointless to bother this is not a stock 4.4.2 rom, hell its not even 4.4.2 but rather a beta 4.4.0.
                      Check for yourselves in the rom its there plain as day under the about tab.
                      This rom wont be improved or worked on with everyone moved on to actually 4.4.2 roms
                        I have issues with cheapcast in all the roms I flashed on mk802iv. Not all videos can be played and no HD. Any fix ?
                          Have you tried D33 kernels for the non beta roms?
