Rooting - Cydia Impactor did not work! But, I had su root access via ADB. So, I manually copied over a new su, set the chmod's, rebooted and boom, I had full root access. Busybox was already installed.
Software Config - Google Play Store reports many apps are not compatible (not a surprise). I was able to sideload quite a few apps, including TuneIn 9.1. Chrome could not be updated (error says "missing critical components" during the install), but Dolphin Browser installed and ran fine.
Clean Up - I used Titanium Backup Pro to remove system apps I did not want, integrate updates to system ROM and make a backup. Love that Titanium Backup Pro app (a bargain for $6 and one license can be used on all your tablets).
Speed - Boots fast and runs apps fast for a dual-core tablet.
Screen - 8" IPS display. Beautiful.
Tablet - Not thin like people commented on Newegg. It has a normal thickness for a tablet. I had no problem with back pressure causing ripples on the screen.
Overall - An OK tablet for everyday use like web browsing, email, WatchESPN, etc. and simple game playing (it ran Angry Birds just fine). An accelerometer is the only on-board sensor. For $70 dollars, it's the cheapest 8" tablet I've seen.
