What i was thinking is, that something is wrong with the internal storage chip. Maybe many bad blocks or something. Check disk in Windows doesn't find anything when the tablet is connected with USB. So I'm thinking maybe the error is in a partition that doesn't get mounted when USB is connected.
The question is if it's possbile to just buy a class 10 32gb miniSD card, partition it properly and use it as NAND and Internal SD. I don't much care if the whole thing doesn't get mounted when USB is connected because the 16gb internal space in the tablet probably will and then I could move files using a file explorer in the tablet (I am guessing the whole internal space could be made to be recognized as ext SD using a script).
The difficult thing, I imagine, is partitioning the card correctly, installing Android in it and actually have the tablet use it to boot instead of the internal chip.
So what do you think? Is this possible at all? I think it would solve all my problems with the tablet.
