Send from nubia z5s mini
Why do we get different AnTuTu result?
Re: Why do we get different AnTuTu result?
Sent from my Nexus 5 using Tapatalk
The benefit is, that you have always a higher minimum frequency, so every app start with it and runs at that minimum al the time and don't have to wait so long if it needs more performance at cpu...
I run my rk3188 at minimum 1008 (at 4 core) and have no head problem, but I'm sure if e.g. XBMC needs more power, it get it faster...
BTW: which landscape apk do you use?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by saor11 View PostWhat's the advantage of setting such a high min? Doesn't the new firmware deal with the CPU clocked speed?
The kernel in the S89 is obviously from a tablet, it uses a hotplug governor which a phone or a tablet uses and in the governor settings like sample time, the sample time is 100000 You need it down at around 20000 for performance so its samples the CPU more and performs tasks quicker. Tablets and phones sit at a low CPU min to save battery, sample slower again to save battery, we have a TV Box plugged in so we don't need the power saving stuff.
Looking at my Nexus 5 phone it regularly sits at a min of 1Ghz ( although that's slightly different as it touch boosts)but 96mhz is crazy low.
The only other effect the kernel can influence is overheating but feeling the box and looking at the temp the heat is low.
There's nothing in the new ROM that changes the kernel, it needs a complete overhaul but we don't have full kernel sources so the devs on here can't do that yet.
Originally posted by saor11 View PostThanks guys for that. Getting there slowly with this box!
There already exit a basic 3.10 kernel source and d33 try first steps but some hours later I see him tinker with rk3188T unlock kernels for JB ...
In the past for the AML8726-MX (g-box2) I only know 1 Linux dev and 1-2 android (nearly) devs...
We will see...RK3288 Devices
Originally posted by saor11 View PostWell fingers crossed they release the sources. This box came with such hype and it was annoying to end up with a problematic item that was released untested . thank god for this place!
Lets see...
I just flashed the new S89 elite ROM.
I get antutu of 31400
My CPU boots at 1.9 now not 1.6.
FYI the kernel source D33 got are no good! It is some kind of Linux compile not Android. He can compile it but it is not at all right. boot.img looks nothing like android and instead looks like Linux. So we need real sources!
So strange. When I boot with the new Roms and only run trickster and set CPU it definitely gives me 1.6max. When I set it to 1.9 after a while it jumps back down to 1.6.
Could it be that the higher frequencies are unlocked but somehow trickster and SetCPU see the inid scaling frequencies and take them as max?
Or that the initd script is interfering with the scaling of the frequencies overall. If you've got a governor telling you your max freq is 1.6 then it will tend towards that even if you've got higher freqs.
Incidentally I can't get over 28500 wish with the new ROMs. Maybe I've just got bad CPU.
I am using Antutu CPU master. On the old ROM it did exactly what your saying. It would jump back to 1.6.
This ROM boots at 1.9 for me.
Remember though I am using the Elite ROM not the Standard. Let me see what the standard ROM does.
Originally posted by saor11 View PostSo how do I increase max and min permanently cause it keeps reverting back for me ?
I'll try reflashing the ROM again later (after my wife goes to bed and i get the TV) and use Antutu CPU master to see what I get.
Incidentally, I've got an elite.
There are currently 1813 users online. 0 members and 1813 guests.
