I have to reboot the X7 and run the Re - alignment on the remote to get it properly functional again. Is there a separate forum where I should ask about this issue? I assume that it's more of a problem to do with Xbmc's interface and not the Neo a A2s hardware/software?
Neo A2 Air-mouse on XBMC and Quickshot V2. Issues?
So I have a Minx Neo X7 flashed with Quickshot V2 I am a very new user to XBMC and have a few issues and questions to work on with it; the most frustrating problem is using my Minix Neo A2 remote/Air-mouse which mostly becomes erratic (lost accuracy in use) when used in the Xbmc UI,
I have to reboot the X7 and run the Re - alignment on the remote to get it properly functional again. Is there a separate forum where I should ask about this issue? I assume that it's more of a problem to do with Xbmc's interface and not the Neo a A2s hardware/software? -
Originally posted by AndroIdJim View PostSo I have a Minx Neo X7 flashed with Quickshot V2 I am a very new user to XBMC and have a few issues and questions to work on with it; the most frustrating problem is using my Minix Neo A2 remote/Air-mouse which mostly becomes erratic (lost accuracy in use) when used in the Xbmc UI,
There are currently 2005 users online. 5 members and 2000 guests.
