Sent from my Nexus 5 using Tapatalk
Why can't I power on the S82 and s89 box with the controller?
Re: Why can't I power on the S82 and s89 box with the controller?
Originally posted by Batfink32 View PostI think the min frequency and hotplug govenor is definitely the problem, it doesn't have the "grunt" to wake it up. The "keep screen on" in developer option is he best fix ATM I think.
If only they would release the kernel... Why are they so uptight
It works!!! No need to install Battery Saver!
******Originally Posted by******Batfink32******
OK, I found it on my phone. You need to go into "about tablet" then press on "build number" 7 times. You should see a notification saying "developer options unlocked"
Come out of the settings then reboot. Go back to the settings and there should now be a 'developer options " setting. Go in there and there is an option for "screen will never sleep whilst charging" The screen will stay on all the time and never turn off now.
Originally posted by antoniovidaljr View PostIt works!!! No need to install Battery Saver!
I have tested this method and it has been working for me and some friends without any problems! It's better than using battery Saver. No need to waste memory running the app in the background.
There are currently 3440 users online. 1 members and 3439 guests.
