MK808B Android 4.2.2 Dual Core mini PC Smart TV HDMI Wifi Bluetooth
CPU: Dual ARM® Cortex™-A9
Processor: RK3066 Up 1.6GHz
Memory and storage: DDR3:1GB Nand Flash:8GB
Size & Weight: 4.0inches (L) 1.5inches (w)
Audio Type: Integrated
Graphics adapter: Integrated
GPU model: quad core Mali-400MP
Video outputs: HDMI
USB: USB2.0 and 5pin Mini usb
Networking: wifi:802.11 b, g, n
Memory card reader: microSD
OS: android 4.2.2
I do not yet feel ready to think about putting other roms etc on the device, as described in detail here, and wonder if those "in the know" could suggest what apps they think they would add to it on arrival?
I would like to use xbmc on it, is there a particular version that is suited to this?
Any helps appreciated.
Thanks.
