FreakTab NewsFeed!
Khadas Edge2 ultra thin SBC is powered by Rockchip RK3588S processor
Created by:
trebor
- Published: 13 September 2022, 07:28
- 28 views
- 0 comments
Found over at CNX Software: CNX SOFTWARE
As noted in the Khadas VIM1S announcement, the company is also preparing to launch the Khadas Edge2 single board computer with a Rockchip RK3588S octa-core Cortex-A76/A55 processor and a thickness of just 5.7mm (before a low-profile heatsink is installed).
The new board follows a similar form factor as the original Khadas Edge board powered by a Rockchip RK3399 processor, except the edge connector is gone, so it can’t be used... -
Created by:
8K TV box powered by Amlogic S928X Cortex-A76/A55 processor showcased at IBC 2022
Created by:
trebor
- Published: 12 September 2022, 09:57
- 57 views
- 0 comments
Via CNXSOFT
Amlogic S928X multi-core Cortex-A76/A55 8K media processor, which may have been initially known as S908X, is being showcased at ICB2022 in Amsterdam in the “SEI 8K Box” developed by SEI Robotics.
Amlogic S908X/S928X was first discovered in a roadmap in 2019 and was expected to launch by the end of 2020 at the time. But after a long wait of nearly three years, the Amlogic S928X processoris finally showing in SEI 8K box with an HDMI 2.1a 8K video interface, supports... -
Created by:
Khadas Events: September 20th 2022
Created by:
trebor
- Published: 31 August 2022, 07:40
- 40 views
- 0 comments
Gadgets 4 Makers!
Edge2, Tone2, VIM1S & BT Magic are coming: September 20, 2022 at 6:00 p.m. GMT +8
https://www.khadas.com/events... -
Created by:
TRIGKEY SPEED S; AMD Ryzen 5 3500H 16Gb Ram 500Gb Storage WiFi 5 Gig Lan:
Created by:
trebor
- Published: 09 August 2022, 05:29
- 17 views
- 0 comments
Another day another mini PC
Today thanks to Trigkey
https://trigkey.com/collections/mini...ducts/s3-3550h
We will have a closer look at the Speed S:
AMD Ryzen 5 3550H
16gb Ram, 500GB Storage
Wifi 5 with Gig Lan, 19v 3A power supply.
https://trigkey.com/collections/mini...ducts/s3-3550h... -
Created by:
Beelink GT King II WiFi 6 Android 11 TV BOX 8GB 64GB Amlogic A311D2 Octa Core LPDDR4 Support 4K 60fps BT5.0 1000M USB3.0
Created by:
trebor
- Published: 28 June 2022, 09:43
- 190 views
- 0 comments
Created by:
What is OOWOW
Created by:
trebor
- Published: 06 June 2022, 21:19
- 35 views
- 0 comments
What is OOWOW
What is OOWOW?
OOWOW is an embedded service (integrated into your device) - it can be run at any time if you need to perform essential maintenance services on your device.
Note: VIM4 is the first device from Khadas that includes the OOWOW embedded service. Since VIM4 comes without any pre-installed OS, users can use OOWOW to select and install the preferred OS.
OS Delivery
OOWOW provides rapid online OS download and installation, which will... -
Created by:
Beelink MINI S Intel 11th Gen 4 Core 2.9Ghz Processor
Created by:
trebor
- Published: 13 May 2022, 01:36
- 47 views
- 0 comments
Intel® Celeron® N5095CPU, DDR4 2400 MHz RAM, M.2 SATA3 2280 Storage, WiFi 5
https://www.bee-link.com/catalog/product/index?id=302... -
Created by:
Khadas VIM4 is launching on 10th May!
Created by:
trebor
- Published: 22 April 2022, 22:18
- 222 views
- 0 comments
Khadas VIM4
KEY FEATURES
Amlogic A311D2
• x4 A73 performance cores at 2.2GHz, x4 A53 efficiency cores at 2.0GHz.
Mali G52 MP8 GPU
• The 800MHz Mali G52 graphics processor and supports 4K UI.
8GB RAM
• 8GB LPDDR4X RAM with 64-bit bandwith and clocked at 2016MHz.
HDMI & DMIC Inputs
• x1 micro HDMI input at 4K 60 fps, x2 digital microphones for versatile AV recording.
Created by:
Logitech's new Lift Vertical Ergonomic Mouse helps relax your hands
Created by:
trebor
- Published: 19 April 2022, 09:41
- 23 views
- 0 comments
Logitech today on April 19 is launching the Lift Vertical Ergonomic Mouse. Priced at $69.99, the new mouse is the latest entry to the Logitech Ergo series. It is designed to help relax your hands, relieve pressure on your wrists, and improve your posture.
Logitech provided us a sample unit for review, and in use for two days, we found that the new mouse sports some unique features that helped improved our workflow a bit. It has a 57-degree vertical design, which takes some pressure... -
Created by:
Amlogic T962E2 quad-core Cortex-A55 TV box board supports 4K HDMI input & output
Created by:
trebor
- Published: 08 April 2022, 09:13
- 52 views
- 0 comments
Amlogic T962E2 is an upgrade to the Amlogic T962E quad-core Cortex-A53 SoC we first found in the Alfawise H96 Mini TV box with both HDMI output and HDMI input ports. The new processor offers similar features but comes with more efficient Cortex-A55 cores, a Mali-G31 MP2 supporting modern Vulkan and OpenGL ES 3.2 APIs, and some other improvements including 4K AV1 video playback.
While mostly designed for Smart TVs, I found the Amlogic T962E processor in a TV box board with up to 4GB... -
Created by:
There are no articles in this category.
Please log in to your account to view your subscribed posts.
There are currently 4216 users online. 1 members and 4215 guests.
