The reason I ask is because I am getting terrible XBMC performance, I can't even play back 720p without stuttering.
VidOn AV200 firmware on CS918S?
Try SPMC (non lib edition) or wololo or vidon.me or beyondxbmc --xbmc builds
Try tweaking the unit abit.. using 'android tuner"
-govenours --max power from 0 to 1 ( disables cores going down -to save power)
-cpu trotle from 700 to 1ghz (default 312 mhz to 1 ghz)
Build.prop tweaks
Titanium backup then deepfreeze some pre-installed apps/services/not needed launcher ect
Xbmc tweaks
-adv xml
-playercorefactory xml <for external player support
Xbmc addons tweak
-disable 'metadata'
Emty Cache every week
-desktop/settings/storage/cache
Anyway.. just a few thoughts
Goodluck
There are currently 2520 users online. 1 members and 2519 guests.
