This is a KitKat ROM, so you need to keep the loader checked the first time you flash it. If you decide to go back to a Jellybean ROM...you must first erase IDB from this ROM before flashing the Jellybean...and flash the loader for the Jellybean ROM (you are on your own for a Jellybean firmware to flash back to...either look on the iFive site, or do a ROM dump of your original firmware before you start, just look around for instructions here on FT).
This ROM is:
Rooted
Debloated
Init.d Support
English Default
Auto APK Install feature on first boot (read my thread on it in the Pipo section)
TWRP Recovery
2, 4, 6, 8, 10, 12gb user app space options by flashing the desired parameter file (default is 4gb)
Boot animation by me
Reboot app by Petrus
First Time User's Guide for flashing instructions and other tips
Modules added for VPN support (not tested)
Adjusted Wifi Power
If you would like future iFive support, please donate at the link in my signature...I would really like to get an iFive to test with.
Download
