is this sufficient? https://github.com/rdavenpo/Linux3188
Best way to Put Linux on CX-919
Originally posted by Jimandroidpc View PostNew to Linux but interested in learning. What is the best way to install Linux on a CX-919 (Original Rk3188) so that the Wifi and BT work? thanks, jim
I tried the image from this thread:
http://www.freaktab.com/showthread.php?14827-Easiest-way-to-try-Linux
I used this image for my CX-919 Stick:
Rikomagic MK802IV New (AP6210)
Works just fine. Also wifi works. I haven't tested bluetooth until now.
But no Mali support for this image. So you can't play games or something else that needs a graphic card.
Just put the image with Win32 Disk Imager tool (Win PC) on a sd card. (Better have a fast SD Card!)
Nothing more to do. You don't have to touch the Nand part of the Android OS System.
The only thing i want to set up now is a boot menu to choose to boot from linux or Android.
Until now, linux boots from sd card, if the sd card is in the stick. If not the Android OS boots.
Fine for testing purposes until now, but not my final solution.
If you want to use linux only, so just leave the card in the stick. If you want to use android again, you have to take the card out from the stick.
Oh, and the linux version is Ubuntu 12.04.
Edit: found itPlease consider making a Donation to freakTab
cx-919 clone
Unfortunately, mine turned out to be one of nasty CX-919 clones and I could not find any working image. The sd image you are referring to is one that I have already tested. I should not have bought it because it was cheap and looked like cx-919.
Thanks anyway.
There are currently 2918 users online. 0 members and 2918 guests.
