Nand size (count 0x2000000 = 17179869184 bytes) Param & Loader (4194304 bytes) (4mb) start offset - 0x00000000 -count (0x2000) Misc (4194304 bytes) (4mb) start offset - 0x00002000 - count (0x2000) Kernel (16777216 bytes) (16mb) start offset - 0x00004000 - count (0x8000) unknown 1 - (12582912) (12mb) start offset - 0x0000C000 - count (0x6000) Boot (16777216 bytes) (16mb) start offset - 0x00012000 - count (0x8000) unknown 2 - (12582912) (12mb) start offset - 0x0001A000 - count (0x6000) Recovery (33554432 bytes) (32mb) start offset - 0x00020000 - count (0x10000) Backup (67108864 bytes) (64mb) start offset - 0x00030000 - count (0x20000) Cache (134217728 bytes) (128mb) start offset - 0x00050000 - count (0x40000) User Data (4294967296 bytes) (4096 mb) start offset - 0x00090000 - count (0x800000) kpanic (4194304 bytes) (4mb) start offset - 0x00890000 - count (0x2000) System (637534208 bytes) (608mb) start offset - 0x00892000 - count (0x130000) unknown 3 - (6291456) (6m) start offset - 0x009c2000 - count (0x3000) User (11934892032 bytes) (11382mb) start offset - 0x009c5000 - count (0x163B000)
Nand Offsets - some info required
Guys, I am making some software and need to know the offsets for certain parts of the Minix Neo x7 nand.I have the following in my NAND after checking:
Code:Last edited by mrdude; 02 May 2014, 07:20.Tags: None
Originally posted by LawlessPPC View PostWe may be able to help each other a bit. Pm me if your interested Sent from my MB860 using Tapatalk
I found that for my minix neo x7 -
user.img (start 0x9c5000 - count 0x14f7000) - (11255414784 bytes) - internal sd card.
I also found that the unknow parts in the nand - are just blank spaces between the partitions and don't contain any data - just ffff's. Basically the nand is just storage area - a loader boots the minix and the parameter file tells where the partitions are located. Each partition contains data. User.img is fat32 and can be opened on a pc with ultraiso. System.img can also be opened with ultraiso.
Found partition size in user.img with winhex:
(partition size - offsets 20 to 23, show this - 00 70 4f 01 = 14f7000) - also shown at offsets 420-423
14f7000 - converted to decimal = 21983232 (pages)
1 page = 512 bytes so 21983232 pages multiplied by 512 = 11255414784 bytes (10734 meg)
A full brick (corrupted loader) can be recovered by putting the minix in MaskROM mode - you can do this by shorting out pins 8&9 on the nand.
An image can be built by using dumps from your minix:
Afptool -pack ./ new.img
Once the image is built it can be put into flashable format:
RKImageMaker.exe -RK31 RK3188Loader(L)_V1.24.bin new.img flashme.img -os_type:androidos
All tools used for flashing and image manipulation can be found on this forum.Last edited by mrdude; 20 May 2014, 13:30.
There are currently 2060 users online. 1 members and 2059 guests.
