JustMe
Final Gotham 13 release
has anyone tried this apk to see if it works
JustMeBugs are Sons of Glitches!
JustMeTags: None
Yes and No
Originally posted by JustMe View Posthas anyone tried this apk to see if it works
JustMe
On my LG 8.3 tablet, Gotham 13 performs beautifully...
Originally posted by Zahir View PostYes, I tried it on the Acemax 30 March firmware, and no, it doesn't work. It will need to be custom-compiled.
JustMe
Clarification
Originally posted by JustMe View Postyou sure this is acemax different person altogether the link its not firmware it xbmc apk
JustMe
I haven't tried the version in your link. Have you?
Originally posted by Zahir View PostWhat I meant was: on my M8 with the 30 April firmware, I tried to run the final release of Gotham (XBMC 13), which I downloaded from the XBMC site. I had to uninstall the RC1 version first. The final version of Gotham didn't work, producing no video. I assume it will have to be compiled specially to run on this firmware.
I haven't tried the version in your link. Have you?Bugs are Sons of Glitches!
JustMe
from xbmc.org
NOTICE: In case you downloaded XBMC 13.0 release on Sunday morning May 4 (May 5th here), please re-download and install it again.
Video playback may have been affected in that version.
JustMe
JustMe
can the problem why the normal gothams only play audio and no video be from this bit of code found in the apk playercrefactory.xml I did same day build date comparision and the normal gothem does not have that in the code only the tronsmart RC1
<!-- MXPlayer Free definition -->
<player name="MXPlayerFree" type="ExternalPlayer" audio="false" video="true">
<!-- Android intent -->
<filename>com.mxtech.videoplayer.ad</filename>
<!-- Hide XBMC -->
<hidexbmc>true</hidexbmc>
<!-- After 2 minutes bump the play count of the item in XBMC -->
<playcountminimumtime>120</playcountminimumtime>
</player>
</players>
les name="system rules">
<rule filetypes="rm|rmvb" player="MXPlayerFree" />
<rule videoresolution="4K" player="MXPlayerFree" />
JustMe
I just got 12 of these M8 boxes, and im a bit upset at how the native builds of XBMC dont work on thes,
its upseting to know the company is making some hacked up version of xbmc to make it work
Originally posted by JustMe View Postcan the problem why the normal gothams only play audio and no video be from this bit of code found in the apk playercrefactory.xml I did same day build date comparision and the normal gothem does not have that in the code only the tronsmart RC1
<!-- Hide XBMC -->
</player>
</players>
JustMe
<!-- Hide XBMC -->
</player>
</players>
JustMe
Originally posted by rlaursen View Postthat is showing its using the mx player rather than stock xbmc player right? I dont care because it plays back perfect but having to always wait for a modified version is kinda annoying.
I mean you can unpack it and include it and recompile the apk and sign it etc
but that is just one change so why people worried about a/v sync issue when they can use native gotham?
Perssonally the issue where the unit switched on and off in standby mode and also switched signal to the tv is a more of a worry , then the 5ghz, then xbmc
JustMe
Originally posted by pigbait View PostI just got 12 of these M8 boxes, and im a bit upset at how the native builds of XBMC dont work on thes,
Next time buy some samples to avoid disappoints ....
@Justme
Do you have a picture when Led turned on during Standby? My screen is Blank on Both Square and S89 Vega ...
Originally posted by TMx View Postnothing unusual have you tried M6? it was same...
@Justme
JustMe
@Justme
when you put it into standy, the tv signal goes off as if the box is off but the light randomly goes on and off. There is no signal to the tv while the led lights up until you awake it from sleep using the remote.
There are currently 5619 users online. 1 members and 5618 guests.
