We just get the new firmware for the Vega s89 standard and elite. The factory just solve the XBMC A/V Sync problem. No other changelog.If you don’t want to flash the new firmware, i am uploading a new XBMC apk, you can just install the apk later.
Update: just upload the xbmc apk, download link is here:
http://www.mediafire.com/download/qh...-Tronsmart.apk
Since in my last firmware release, some standard users report they lost the 5g wifi, so please help to check the new firmware, if it is ok? because i just get the firmware, haven’t got time to test, if you don’t want to take the risk to try, you can wait for my test result tomorrow.
ok, here we go
New stock firmware for tronsmart vega s89 elite
New stock firmware for tronsmart vega s89 standard
The both file are all img file, you should use amlogic usb tools to flash them. the instruction is here
you should use method 2.
Please fogive the slow download speed, i haven’t got time to reupload to other place, will finish that tomorrow.
If you can’t wait to try this, please help to leave feedback.
Eric
Geekbuying
