What is the best build of XBMC for Allwinner A10 Android TV box
    Okay the story goes like this I brought these Keedox TV boxes from Amazon and I thought they were rock chip base boxes but they are all-winner which is a hole different animal to deal with.
    The box plays 1080p and 720P stream movies no problem through ES file Explorer Media Player from my PC, but when I try to play same files through the XBMC it plays horribly, I tried some other nightly builds from XBMC and some custom builds recomended by forums and sites dedicated to Allwinner chipset and they're all crap. The only one of these XBMC I had work without any sluggish start-up and plays 720p only great files (xbmcapp-armeabi-v7a-debug-20131009-makesmarttv_dot_net-mxplayer_fix) crashes 30 minutes after start.
    So if you know of any XBMC build that's will play 720p and 1080p on a Keedox Android TV box with a Allwinner A10/A20 chipset I would greatly appreciate it.
    Info
    D/l
    お探しのページが見つかりませんでした!
    Or
    Newer version
    お探しのページが見つかりませんでした!
    Perhaps..
    Goodluck
      Update..
      I just noticed that Mele has a special build of xbmc/vidon.me for the allwinner a10 units
      Here is the link
      百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
      Goodluck
        Is anyone have trouble with acestream player on this box. My screen freezes. Help plz
