NEW - CX-803 Android 4.4.2 KitKat Rooted (Kernel1080p)
Originally posted by adch View PostAnyone has a back up link? The link in the first post is gone. Thanks
To report Bug with the kitkat release
Good Day Dumonde,
Thanks for the great kitkat release /I tried to use and discover some issue
There is some issue need to be fixed.
- There is a red frame issue in chrome browser.
-The is wifi slow issue causing buffering of video and downloading apps in Google play a bit slow .
Fix it by downloading an app and applying wifi tweak on the apps.[https://play.google.com/store/apps/details?id=com.arrancamos.tweak.n7k.ics&hl=en]
Wow,Now Buffering video is fast ,browsing and downloading app experience is better .
-Mic don't work[using the same device here :http://www.freaktab.com/showthread.php?3549-Another-clone!-(CX803-FX5)-but-with-external-antenna-and-reset-switch-button!!!/page3 ] >>any possible to tweak it to work
-Tried the miracast. Show slide is ok. Playing 720 youtube video is good .
sharing screen playing a 720P mkv on BSplayer is totally not possible [is there possible to fix and optimized]
Thats all for now .Last edited by frenco; 31 July 2014, 01:24.
Originally posted by Dumonde View PostNew version with latest changes from rockchips
http://goo.gl/DAuRIR
Tried the latest firmware .
-Wifi Slow issue "solve ":Is now blazing fast.
-Chrome browser : Initial 3 tabs there is still red frame issue .However after the 3 tabs .The red frame just disappear .Continue using there is no more red frame .
Allways the Initial first 3 tab you open there is redframe issue .
-shutdown button works perfectly
Request a separate kernel.
-720p kernel .Cpu > running at lower clock speed similar to http://www.freaktab.com/showthread.p...Custom-ROM-1-7. Cause the the CX-803 stick is running really hot when running kitkat. When running Fins 1.7 rom [the cx-803 stick is extremely cool.]
More testing on the miracast later tmr .
Thanks again for the great work.
@ Dumonde
HI, could it be that the 3066 Chip in the CX803 is not supporting Miracast?
I have your newest rom working but in the android settings menu in the "display" tab there is no Wireless Display option how here in point 8. here http://blog.laptopmag.com/miracast-android-mini-pc
I use intel WIDI with my notebook, the pairing is working (shows in Paired groups) in the WifiDisplay App but it don't shows
the screen from my notebook.
I don't get it.
Originally posted by Dumonde View PostAnother update (audio, USB camera, suspend/restore, etc...)
http://goo.gl/iY5JS3
-5.1channel sound /haven't tested ,still waiting for my Y hdmi cable
Not working /Tiny little bit of problem
-internal Mic not working .
-wifi miracast .trying a few times to setup before is working . But once done /Miracast works better on this version. [no out of sync issue . Improvement needed to the detection ] .Last firmware version miracast detection is faster.
-The Stick is running pretty hot in temperature under 1.6ghz. Can you provide a Factory clock down version 1.2ghz + 720P kernel for this firmware ?
-Build prop correction needed / as there is Google play error . Maybe you may wish to spoof the device to Samsung phone .
That about all. Will keep testing for possible bug .
-Build prop correction needed / as there is Google play error . Maybe you may wish to spoof the device to Samsung phone.Last edited by Dumonde; 20 August 2014, 15:48.
There are currently 1405 users online. 0 members and 1405 guests.
