Picuntu 5.1
Return it back to Android. How to do that ?
ok i have install Picuntu to my mini-pc. I get a communed line with login and password. But i like to have one with gui. What should i do?
Also now when i connect the device to my PC it is not recognized. The thing is i will like to return it back to Android. How to do that ?
Originally posted by avarnaliev View Postok i have install Picuntu to my mini-pc. I get a communed line with login and password. But i like to have one with gui. What should i do?
Originally posted by avarnaliev View Postpicuntu 5.1
I can log in no problem but how to remove it and go back to android ?
Originally posted by conftap View PostHas anyone tried picuntu 5.1: http://home.g8.net/index.php/14-samp...usty-14-04-lts on an rk3188 device?
We are shortly to release. 5.5 to address the 3188 chipsets and to upgrade to Trusty LTS support.
Alok
Originally posted by aloksinha2001 View PostPicuntu 5.1 is for dual core /3066 devices only.
Alok
I have a mk908v3 and installed picuntu 4.5, then upgrade to saucy .
It is not stable, it reboot itself after (idle) a few hours ( few days if lucky).
I cannot find any traces and what caused problem..
Really wanna try the 5.5 ..
Another strange thing is that I got no display at all until I use a kernel tree with it66121 support, and that I need to link hdmi to lcdc0 instead of the default lcdc1. The latest 3.0.101+, for example, which has cat66121 instead of it66121 cannot generate any screen output from my device. I added some dumps and found that probe of the it66121 device fails when using the cat66121 driver.
wifi doesn't work (yet), but it doesn't matter since I prefer using usb ethernet for stability.
There also seems to be problem with the nand under linux. My rootFS is on micro SD and I can mkfs.ext4 and mount the unused nand partition, but every time when I copied my SD to the nand and tried booting from it (by changing cmdline in .config to root=/dev/mtdblock4), it couldn't boot and also the nand partition would be corrupted. Hence I now have to stick to SD.
BTW, the apt repository of picuntu doesn't seem to be that stable, for example, the repository for picuntu 0.9RC3 which I installed last year for my mk808b is now no longer working. Hence the rootFS I'm now using for my mk908v3 is built by myself based on debian wheezy using debootstrap.
Re: Picuntu 5.1
Alok
Any clues on the release date?
Sent from my M6 using Tapatalk
There are currently 2349 users online. 1 members and 2348 guests.
