MK809IV Rockchip RK3188-T bootloop or shutdown
    Dear all,
    I bought an MK809IV from China yesterday with android 4.2.2. Everyhing worked fine, I managed to set it up the way I wanted, but i didn't have a router to connect to the internet. Today a friend gave me an ZTE USB 3G dongle to connect to my MK809IV. Everthing worked fine, I had internet, I managed to setup a google account and watch 1-2 videos on youtube. After about 5 minutes the screen started to make some purple horizontal lines. I was scared that something happened to the device and pluged it out.
    After that I decided to remove the ZTE 3G adaptor and restart the MK809IV. Now I see some blue vertical lines in some applications (you can see this in the image below, on the left side), but only for 1920x1080 resolution. If i change the resolution to 1280x720 I no longer see the blue lines.
    Let's say that isn`t a big problem, I can work with 720p resolution, but after about 2-3 minutes, the MK809IV restarts by itself (doesn`t matter what resolution I set) and enters a bootloop. I tried this several times with the same result.
    The device has a built-in recovery mode and I managed to reset it to factory settings but with no succes, the reboot and bootloop still persists.
    Could this be a rom problem? Or a hardware problem?
    I am not sure what rom to install because from what I can see on the forum, MK809IV doesn`t really exist and it may be a copy of another device.
    After I removed the covery I saw that the chipset is a Rockchip RK 3188-T, Quadcore 1.4Ghz, 8GB memory, AP6210 wifi and bluetooth.
    I linked some photoes of the devices.
    Please someone help me sort this out.
    An update..
    I managed to flash the KitKat 4.4.2 from this post and after a restart it booted into the rom.
    But I have the same problem: after about 5 minutes it freezes and restarts by itself and is stuck in the bootloop (linux penguins at the top left).
    I think my device is overheating or something, altough it isn`t too hot or anything.
    Can anyone help me with any suggestions?
      Which ROM did you flash?
        Originally posted by sonicatu View Post
        An update..
        I've got to worry you but it is a hardware failure.Connect your device even without the HDMI adapter. Graphics raining, maybe you will help undress additional cooling equipment and see if you have a heat sink on the processor.
        MY MINI PC: C4,CS918,M8,M8C
          Thanks, I managed to return it. Waiting for a new one
            AW: MK809IV Rockchip RK3188-T bootloop or shutdown
            I don't think it is a Hardware Failure. It is a Power Failure. The PSU for your Stick have not the power needed for both. Use a USB switch with a own PSU and all will Work.
            Regards
            Neomode
              Regards
              Neomode
              I fix mini pc, and I know what he writes is a processor failure, and exactly cold February happens so I had a few such cases. This is not the fault of the power supply
                hello, i have i similar problem with mk809 IV RK3188T bought, my problem is after i upgrade from 4.2.2 to 4.4 i have an endless boot loop ( i see on boot the four penguins on and on...) never boot up.
                How did you solved that problem?
                  Same here, pretty much stuck here.
                  Same here. 4 x tux pinguins and just a flickering ANDROID logo. It won't even boot in OTG modus.
                  I have done some flashing of the Android kind(Phones/Minix,etc.) But never seen this before.
                    The Reason is maybe the Wrong Kernel.
                    Because a RK3188-T is not a Normal RK3188.
                    The difference is they are out selected RK3188 they can only run with 1.4 GHz.
                    Try one of this kernel depending on your Wi-Fi Chip-->
                    http://www.freaktab.com/showthread.p...All-(well-most!)
                    Neomode
