I once flashed my mk908 II with the fineless ROM 1.6 without any issue . today I try to flash different linux kernel image , after I lower format my device and copy new image to device with ROM_Flash_Tool_21.exe , I got download image failed issue. I thought it may the image file issue and try to flash the old image back . but I got same issue when flash the file .
I use another version rk_flash_1.37(RKAndroidTool.exe) do the same thing , same result .when doing lower format , the logs as below :
INFO:Start to erase IDB
INFO:Start to lower format
INFO
I do remember the total size once was 2048 when I can successfully flash the ROM, now it shows 341 , it that mean something broken and NAND size could not be retrieve as before ? which I think is the reason image file could not be download to ROM .
Is anything I can do for this ? anything log I can see to determine the issue ?
can anyone share some thoughts on it .
