JustMe
Eric and Gotham RC1 for tronsmart
Eric you mentioned the a/v sync would not be suitable for square m8, why is that?
JustMeBugs are Sons of Glitches!
JustMeTags: None
Originally posted by JustMe View PostEric you mentioned the a/v sync would not be suitable for square m8, why is that?
JustMe
yes, the tronsmart fix can't be used on square m8, because the different factory hacked the xbmc according their own device.
EricLooking for developers
Originally posted by geekbuying View Postthe square M8 xbmc also have A/V sync problem? i never hear this feedback before? are you sure?
Eric
Can I please have square m8 xbmc player rc1 personally I cannot see the difference at the moment only tested like live streamsBugs are Sons of Glitches!
JustMe
There are currently 1552 users online. 1 members and 1551 guests.
