Tronsmart s89 - Micro-stutter/Choppiness from video playback
Originally posted by zoelechat View PostIntelligent frame creation tech (as well as Samsung Motion Plus and others brands) needs sync signal from source to work properly. So, as long as S89/XBMC won't handle 24p/Vsync there will be stutters, already noticeable without frame creation, just amplified by it...
I'm asking because I give it a short try at my rk3188 device but at that moment I setup the box to 24p the cursor is sooo choppy (movement not liquid)...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostDos it mean, the box has to be setup to 24p to use the vsync at xbmc?
About choppy cursor movement in 24p, it's totally normal because 24fps is not enough for human eye to consider a smooth movement. This mode is only due to fit 24p movie...
Anyway, what we expect is to have both options in xbmc funtionning ("adjust refresh rate to video" and "Vsync"). For now, none of them are effective (as I already said, xbmc even reports 60hz when box is set to 50p)Last edited by zoelechat; 16 May 2014, 17:29.
Ahh, ok, THX
But maybe will it be possible to switch (automatically) to 24Hz by xbmc and automatically switch back to e.g. 60Hz at the end of the video/xbmc?RK3288 Devices
This has to be implemented by xbmc developers according to s89/s802 hardware. It is not a firmware issue, even if being able to manually set 24p in system could be a temporary solution for 24p playback.
Originally posted by zoelechat View Post... both options in xbmc funtionning ("adjust refresh rate to video" and "Vsync"). ...
is it the "Sync playback to display" option?RK3288 Devices
Originally posted by farhan View PostLooks like the vidon av200 android box allows you to choose 1080p 24hz for the system:
Why doesn't the tronsmart allow this?
Originally posted by no_spam_for_me View PostIs the Vsync also found here
is it the "Sync playback to display" option?)
Vsync is not in video settings but in system settings:
("Vertical blank sync")
Originally posted by zoelechat View PostNo, this option is the one I called "adjust refresh rate to video" (raw french translation)
("Vertical blank sync")that I found out by my self...
But the vsync not (ever body talk about vsync settings but not where...)
THXRK3288 Devices
Re: Tronsmart s89 - Micro-stutter/Choppiness from video playback
Originally posted by TMx View Postlooking good on paper but double the price ...(actually its Mele A1000G/M9 inside)
☆sent from an xNote powered sm-n900t w/tapatalk☆
There are currently 3100 users online. 0 members and 3100 guests.
