NEW FIRMWARE FROM UGOOS WORKS ON OUR BOXES!
    My first impressions are that this is a very stable build. Uses Gotham RC1.
    Not rooted, but use Easy Root zip and it's done.
    Still no paid apps...but otherwise feels solid and quick.
    Download takes 47 seconds
    They used old 3.10.10 Kernel
    Added their boot animation, Changed device name in Build.prop rest is same, added 2 apps (chrome browser and ES file explorer)...
    My Antutu score gone down from 19000+ to 16000+
    Bluetooth found g910 gamepad and paired but not working...
    Launcher is same; Laggy
    XBMC RC1 Compiled Apr 27 2014
    nothing special I'm going back to 6-5-2014-- 3.10.33 Kernel
    Thanx for sharing
      Thanx for sharing
      Agreed !! Why are they still releasing firmware with Gotham RC1 when final is available.
      Airplay in XBMC pushes video and no Audio
      Airplay in Android pushes audio and no Video
      Dont like bar at bottom of launcher... No minimize or auto hide
      Antutu Score : 19210
      This is after adding a few apps. Wonder why yours dropped to 16000 ?
        got around 18k after few more attempts but also had that snowy kind of weird white screen so Im installing 3.10.33 Kernel back...
        has anyone succeeded to push that 96mhz min. CPU clock any higher ? Rooted box tried many apk but no joy so far...
          I think the builds of these units maybe poor and no quality control in building them I ordred the 2 units both had diferrent scores out of the box and also different wifi signals
          Hope this unit does not become box of the forgotten world
          Bugs are Sons of Glitches!
          JustMe
            Many Versions of Motherboards available, my test box V0.92 with samsung nand chips , v0.91 Hynix
            on the other hand Antutu and Antutu X versions giving different scores ...
            search for X version in Aptoide you will see that version has lower scores God knows why
            P.s you can't expect reliable wifi without U.FL connector ... little extra heath while soldering = damaged wire insulator = short circuit !
              Many Versions of Motherboards available my test box V0.92 with samsung nand chips , v0.91 Hynix
              big difference in score even with same app we are talking 4500 odd, as said before we need these developers who release these boxes to make things open source and also for them to iron out bugs
              I be happy with blinking light, blue tooth fixed for game pads although blueooth file transfer works and also stable xbmc
              then I can enjoy my new unit because at the moment the same video on my android looks lower res than my xbmc on my pc look slike actual dvd quality via stream repo
              JustMe
              JustMe
                JustMe
                Very True !
                Thing is If you are a reseller and Bluetooth in the specs sheet , it should Work.
                Blinking LED means Faulty unit for the End user = complaints or returns ...
                Why don't we have Power OFF option?
                why is min. CPU freq. is 96mhz ? to save the battery
                Many Brilliant Developers asking for the source ,
                why don't you Let people work on your product development ? is that because they are not asking for money?
                  I think they choose 3.10.10 kernel due to 5ghz issue
                  JustMe
                  JustMe
