deleting from the top bar ?
Originally posted by Brinis View Postok when i download something on googleplay then its shows the download thing and after that the install thing in the top of my screen how do i get this away ? like clear the screen. ? if you know what I'm talking about.
Originally posted by Brinis View Posti wat to keep the apps.i just want to delete the things that shows that i download them. it shows in the to of my screen.
JustMeBugs are Sons of Glitches!
JustMe
If you want to remove the top bar altogether, try editing this in build.prop
persist.sys.hideStatusBar=false
Change it to true and reboot. Note you must be rooted.
I have not tested it but in theory this should remove it.
Originally posted by Drum View PostAre you just talking about the indication / notices on the top left of your screen?
You can just grab the bar with your mouse, drag it down, then hit the target to clear the notices.
Originally posted by Brinis View PostThats is what I'm talking about. But I don't have a mouse I use a keyboard but there is a touchpad on it. I can't do it with the remote ?.
Originally posted by Drum View PostI don't think you can do it with the remote supplied with the unit. I'll try when I get home. Touch pad might work?? A mouse or some pointing device is a pretty handy thing to have, maybe you need to buy another toy.
New toys is never bad.so maybe i shall just do that.
Originally posted by Brinis View Postso witch one will be best just so i get the right one. and it has to have play and stop and all then.
There are currently 4928 users online. 2 members and 4926 guests.
