I've read a tone of articles but I can't identify what must I do to make it dual boot with a linux version, so I will be capable of watching HD movies. I am posting the specs of my mini pc and if someone can help me or guide me to an article explaining the procedure, I will be really thankful.
System (Android 4.2.2)
Model | X5II |
Manufacturer | rockchip |
Device | rk31sdk |
Product | rk31sdk |
Brand | rk31sdk |
Android Version | 4.2.2 (Jelly Bean) |
API Level | 17 |
Build ID | JDQ39 |
Fingerprint | rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.zgq.20140306.174806:eng/test-keys |
Size | 1280x720 |
Refresh Rate | 60 Hz |
Default Orientation | Portrait |
Physical Size | 9.16" (23.26 cm) |
Logical Size | Large |
Density | 160 dpi (Medium) |
Pixels Per Inch | X: 160.42; Y: 160.16 |
Processor | ARMv7 Processor rev 0 (v7l) |
Cores | 4 |
Max Frequency | 1416 Mhz |
Instruction Sets | armeabi-v7a, armeabi |
SIMD Instructions | NEON |
System RAM | 1874 MB |
JVM Max Memory | 80 MB |
Internal Storage | 2015 MB |
External Storage | 4464 MB (Removable) |
General
Renderer | Mali-400 MP |
Version | OpenGL ES-CM 1.1 |
Vendor | ARM |
Texture Size | 4096x4096 |
Texture Units | 8 |
Viewport Size | 4096x4096 |
Modelview Stack Depth | 32 |
Projection Stack Depth | 32 |
Texture Stack Depth | 32 |
Lights | 8 |
ETC1, Paletted |
GL_EXT_debug_marker GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_size_array GL_OES_point_sprite GL_OES_texture_npot GL_OES_query_matrix GL_OES_matrix_palette GL_OES_extended_matrix_palette GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_draw_texture GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_framebuffer_object GL_OES_stencil8 GL_OES_depth24 GL_ARM_rgba8 GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_OES_texture_cube_map GL_EXT_discard_framebuffer GL_EXT_robustness |
OpenGL 2.0 (Mali-400 MP)
General
Version | OpenGL ES 2.0 |
Vendor | ARM |
GLSL Version | OpenGL ES GLSL ES 1.00 |
Texture Units | 8 |
Vertex Textures | 0 |
Combined Textures | 8 |
Renderbuffer Size | 4096x4096 |
Cubemap Size | 1024x1024 |
Vertex Attributes | 16 |
Vertex Uniforms | 256 |
Varying Vectors | 12 |
Fragment Uniforms | 256 |
Int | [-2^24, 2^24] |
Float | [-2^127, 2^127], 2^-23 |
Low Int | [-2^11, 2^11] |
Medium Int | [-2^11, 2^11] |
High Int | Not available |
Low Float | [-2^15, 2^15], 2^-10 |
Medium Float | [-2^15, 2^15], 2^-10 |
High Float | Not available |
ETC1 |
GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness |
Graphic Modes (RGBA 32bit)
RGB 16bit (565) |
RGB 16bit (565), Depth 24bit, Stencil 8bit |
RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x4 |
RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant |
RGBA 16bit (5551), Depth 24bit, Stencil 8bit |
RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x4 |
RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant |
RGBA 16bit (4444), Depth 24bit, Stencil 8bit |
RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x4 |
RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant |
RGB 32bit (888) |
RGB 32bit (888), Depth 24bit |
RGB 32bit (888), Depth 24bit, Stencil 8bit |
RGBA 32bit (8888) |
RGBA 32bit (8888), Depth 24bit, Stencil 8bit |
RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x4 |
RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant |
Accelerometer
Vendor | SYM |
Range | 39.2266 m/s² |
Resolution | 1.0 m/s² |
Power | 0.3 mA |
Delay | 20000 μs |
Vendor | SYM |
Range | 360.0° |
Resolution | 0.01° |
Power | 0.5 mA |
Delay | 100000 μs |
Vendor | SYM |
Range | 1.0 |
Resolution | 0.01 |
Power | 5.9604645E-8 mA |
Delay | 100000 μs |
Vendor | SYM |
Range | 34.906586 rad/s |
Resolution | 7.0E-4 rad/s |
Power | 0.07 mA |
Delay | 2000 μs |
Vendor | Google Inc. |
Range | 1.0 |
Resolution | 5.9604645E-8 |
Power | 0.37 mA |
Delay | 20000 μs |
Range | 19.6133 m/s² |
Power | 0.37 mA |
Delay | 20000 μs |
Power | 0.37 mA |
Delay | 20000 μs |
Range | 360.0° |
Resolution | 0.00390625° |
Power | 0.37 mA |
Delay | 20000 μs |
Power | 0.37 mA |
Delay | 2000 μs |
Codecs (42)
OMX.rk.video_decoder.avc
Media type: video/avc
Color Formats: | YUV420SemiPlanar |
Profiles: | Baseline (1), Baseline (1b), Baseline (11), Baseline (12), Baseline (13), Baseline (2), Baseline (21), Baseline (22), Baseline (3), Baseline (31), Baseline (32), Baseline (4), Baseline (41), Baseline (42), Baseline (5), Baseline (51), Baseline (Unknown), Main (1), Main (1b), Main (11), Main (12), Main (13), Main (2), Main (21), Main (22), Main (3), Main (31), Main (32), Main (4), Main (41), Main (42), Main (5), Main (51), Main (Unknown), Extended (1), Extended (1b), Extended (11), Extended (12), Extended (13), Extended (2), Extended (21), Extended (22), Extended (3), Extended (31), Extended (32), Extended (4), Extended (41), Extended (42), Extended (5), Extended (51), Extended (Unknown), High (1), High (1b), High (11), High (12), High (13), High (2), High (21), High (22), High (3), High (31), High (32), High (4), High (41), High (42), High (5), High (51), High (Unknown) |
OMX.rk.video_decoder.vpx
Media type: video/x-vnd.on2.vp8
OMX.rk.video_decoder.h263
Media type: video/3gpp
Profiles: | Baseline (10), Baseline (20), Baseline (30), Baseline (45), ISWV2 (10), ISWV2 (20), ISWV2 (30), ISWV2 (45) |
OMX.rk.video_decoder.m4v
Media type: video/mp4v-es
Profiles: | Simple (0), Simple (0b), Simple (1), Simple (2), Simple (3) |
OMX.google.amrnb.decoder
Media type: audio/3gpp
OMX.google.amrwb.decoder
Media type: audio/amr-wb
OMX.google.aac.decoder
Media type: audio/mp4a-latm
OMX.google.g711.alaw.decoder
Media type: audio/g711-alaw
OMX.google.g711.mlaw.decoder
Media type: audio/g711-mlaw
OMX.google.vorbis.decoder
Media type: audio/vorbis
OMX.rk.video_encoder.vpx
Color Formats: | YUV420Planar, YUV420SemiPlanar, Surface |
Profiles: | Main (Version0), Main (Version1), Main (Version2), Main (Version3), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level) |
OMX.google.h263.encoder
Profiles: | Baseline (45) |
OMX.google.mpeg4.encoder
Profiles: | Core (2) |
OMX.google.amrnb.encoder
OMX.google.amrwb.encoder
OMX.google.aac.encoder
OMX.google.flac.encoder
Media type: audio/flac
AACEncoder
AVCEncoder
OMX.rk.video_encoder.avc
Profiles: | Baseline (1), Baseline (1b), Baseline (11), Baseline (12), Baseline (13), Baseline (2), Baseline (21), Baseline (22), Baseline (3), Baseline (31), Baseline (32), Baseline (4), Baseline (41), Baseline (42), Baseline (5), Baseline (51) |
OMX.google.raw.decoder
Media type: audio/raw
OMX.google.mp3.decoder
Media type: audio/mpeg
DTSDecoder
Media type: audio/vnd.dts.hd
WMADecoder
Media type: audio/x-ms-wma
WMAPRODecoder
Media type: audio/x-ms-wmapro
AC3Decoder
Media type: audio/x-ms-ac3
RADecoder
Media type: audio/vnd.rn-realaudio
FLACDecoder
WAVDecoder
Media type: audio/wav
AVCDecoder
AVCDecoder_FLASH
AACDecoder
AACDecoder_MIRRORING
RVDecoder
Media type: video/vnd.rn-realvideo
FLVDecoder
Media type: video/flv
M2VDecoder
Media type: video/mpeg2
VC1Decoder
Media type: video/vc1
M4vH263Decoder
M4vH263Decoder
M4vH263Decoder
Media type: video/mjpeg
VPXDecoder
VPXDecoder
Media type: video/vp6
Features (44)
Graphics
OpenGL 2.0 |
com.android.settings.battery |
android.hardware.audio.low_latency |
android.hardware.bluetooth |
android.hardware.camera |
android.hardware.camera.any |
android.hardware.camera.autofocus |
android.hardware.camera.flash |
android.hardware.camera.front |
android.hardware.ethernet |
android.hardware.faketouch |
android.hardware.faketouch.multitouch |
android.hardware.faketouch.multitouch.distinct |
android.hardware.faketouch.multitouch.jazzhand |
android.hardware.location |
android.hardware.location.gps |
android.hardware.location.network |
android.hardware.microphone |
android.hardware.nfc |
android.hardware.screen.landscape |
android.hardware.screen.portrait |
android.hardware.sensor.accelerometer |
android.hardware.sensor.barometer |
android.hardware.sensor.compass |
android.hardware.sensor.gyroscope |
android.hardware.sensor.light |
android.hardware.sensor.proximity |
android.hardware.telephony |
android.hardware.telephony.cdma |
android.hardware.telephony.gsm |
android.hardware.touchscreen |
android.hardware.touchscreen.multitouch |
android.hardware.touchscreen.multitouch.distinct |
android.hardware.touchscreen.multitouch.jazzhand |
android.hardware.usb.accessory |
android.hardware.usb.host |
android.hardware.wifi |
android.hardware.wifi.direct |
android.software.live_wallpaper |
android.software.pppoe |
android.software.sip |
android.software.sip.voip |
com.google.android.feature.GOOGLE_BUILD |
com.nxp.mifare |
Other Apps
Created with Hardware Info 3.0.2
