To stop confusion now, THIS IS NOT ICS! It is a GingerBread Kernel with a Honeycomb system! However, you 9G2 people that upgraded to the 9G3 ICS ROM, you might want to give this ROM a go! In my opinion with 512KB RAM, it vastly out performs ICS.
I feel really good about this port even though I do not have a 9G2 and cannot fully test it. Using my 10G2 kernel it boots and everything seems to work. Additionally the scripts I wrote to make this ROM worked 100% flawless on the 9G2! So thats good news. It means other than the kernel, the ROMs are almost identical!
I think this should work just as good as it does for the 10G2!
PLEASE READ the README.TXT for instructions and what this ROM is about!
You can also read about it on the 10G2 here to learn more about it:
http://www.freaktab.com/showthread.p...ersion-2-1-CWM
REMEMBER! Just like most my ROMs that have major changes to it, ERASE IDB and FLASH THE LOADER! Do this before reporting any problems! You can have screwy things happen if you do NOT erase IDB. Loader is also very important!
________________________
Now this is a BETA TEST ROM! I cannot fully test everything! So you are CRASH TEST DUMMY'S
When reporting problems please try to be as detailed as possible! If there is no detail to your problem and the steps you took to make the issue happen, I cannot help much. So to help make this ROM better for everyone, please be a good tester and document the issue as best you can!
Also those that know how to use ADB or pull the logcat file, this will help a lot! So if you know how to do this when testing, please supply a logcat dump.
___________________________________
So you know this is not my 2.1 ROM! It is a 2.0 BETA ROM!
1) It is NOT debloated
2) It has older Google Files which can be updated by the Google Play store
3) It does not have ClockWork Mod
4) etc..... It was made for BETA testing and I did not want to make too many changes for the test.
Finally after testing and any fixes needed, I will update the ROM to what I call V2.1
It will be debloated
It will have ClockWork mod
It will have App Injector to put back stuff
It will have all the latest Google files and APPs.
OK on with the ROM.
Here is the download:
ROM -> Arnova 9 G2 - "GingerComb" Finless 2.0 BETA TEST (102 megs)
Enjoy and happy testing!
