Mmove apps to extern sdcard but no found mount for extern sdcard
    I have a m8 square box with rooted rom xbmc rc.
    This box has a 8GB internal sdcard. I extended that with a 32GB external sdcard. Now i would like to move installed apps to my external sdcard (because i can't install apps on that extern sdcard, i have to move them).
    Now my external sdcard is mounted and can fully be used and seen in es explorer. But apps like move2sd can't see de sdcard mounted. There is no mount in /mnt, but a sdcard1 link. For the internal sdcard there is the path: /mnt/dev/0 (if i remember correctly).
    Is there a solution?
    RK3288 Devices
    - Overview BOX (LINK !)
      Thanks for the reply.
      So we have to wait for a fix...
