Jelly Bean on Polaroid?
    Just wondering if this may be possible, since they had it running on the old nexus. It may fix all those Netflix problems ppl, including myself, have been having (with the 701s).
    working on this port for PMID702c
    this is on my list, i have to finish my kernel and kernel modules first,
      pmid702c
      would the one your making be compatible with the PMID702C
        jelly bean patch for polaroid pmid702c will be released tmrw morning.
          Re: Jelly Bean on Polaroid?
          Please tell me that you're not being sarcastic.
          Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
            It should be available for download around 7am est or sooner its working well Netflix, YouTube HD are working, biggest issue I have at this time is the gallery app is not working so it crashes the camera when you take a picture.
              Looking forward to it, thanks for all the hard work, your CM9 compatability made this tablet worth having.
                Hey William,
                You have been doing alot of good work for the 702,703 and the 7xc. Thank you for that. Unfortunately, I own a 701c(running the ICS for the 701i), I was just wondering if you would be able to port either CM9 or the Jelly Bean rom over to the 701? I'm sure there are a few of us still here and I know I would be willing to test it, and help out anyway I can...
                Either way thanks for all the hard work,
                John
                  Originally posted by jtintle View Post
                  Hey William,
                  John
                  I have a 701C as well and would kill to have jb as i do on my gnex. I would like to try the 702 port but affraid i may crash my 701 how different are these two products?
                    I'll look in to it, check back on Monday, i should be able to have some thing up by then.
                      CM10 Installation
                      http://www.freaktab.com/showthread.php?1496-Polaroid-PMID702c-amp-PMIC703-CM10-Jelly-Bean-Compatibility
                        701C
                        Anyone try this on the 701s yet? Currently running the 4.0.4 from Onda, would like to see how jelly runs.
                          Not yet, been busy at work, to give it a try. The one good thing about 701c is its really hard to brick it.
                          Sent from my Admire running Lazy M6 with Tapatalk
                            If your going to try I would try Christian Troy's rom straight, do not use my compatibility zip as it is only for A13 tablets the only 701 series that has the A13 is the PMID701x13 and its partition size is to small to run JB well enough and it does not have the same gsensor as the 702 series so screen rotation wont work. Late Monday or Early Tuesday morning I will have CM9 / AOKP out for testing with CM10 to follow after, for the 701 series devices, I will only be doing 701 devices that have the 500mb partitions for CM10 at first, if anyone with ICS based 701 series devices could please post screen shots of your android system information page as well as list what devices it is, a lsmod print out would be helpful as well so I can see what kernel modules each device uses. If it works out I might be able to make one compatibility that will work on all the 701 devices
                              Well I tried to flash Christian Troy's CyanogenMod 10 onto my 701c. Well I had mixed reaction to it. I used CWM-based Recovery v5.5.0.4 from killer klink, it flashed the rom, booted it to the lock screen. however my touch screen and auto-rotate would not work, so I'm figuring it has to do with the screen drivers..I didn't use any of the Compatibility zip's out there, I will be trying to find the closest one to the 701 and give it a try, but I thought I would share that it does in fact boot into CM10
                              Edit:
                              I got CM10 working on my 701C. I used the MOMO9 Compatibility zip. The screen does not rotate, and the hardware buttons are a little wonky, Power buttons works normally, home button works fine, the back button works as the menu button. Those are just the early findings...hope this helps some people, plus maybe we can get a dev or 2 to write up a proper Compatibility zip.
