If you Stick will not seen by the Computer you can make a NAND Reset of the Stick.
Then you can reflash it.
For your Sticks it is a Normal MK809III but the Wifi has change to Media Tek Chip.
They are not Bad by the Way. I will try to make a Version with this DriverĀ“s must see where i can merge them.
When I go to the first link, there is so many links.. Will the RTL8188EU under "STICKS" be the right one? And what about the second link? Should I do both or just the first RTL8188EU even though mine is RTL812385? kernel_rtl8188eu_SD (1).img
EDIT: Okay, I've downloaded the one in the second link named "Kernel_rtl8188eu_SD.img", but which file is to be replaced?
Neomode
The first is proably Media tek but the second certainly isn't.
There so many versions of the 809 now its gotten nuts.
So what should I do now? I'm a bit confused!
I got an answer from the seller providing me with this link:
http://pan.baidu.com/s/1o62RoEIThe file name is "T010_publice_AP6210_20130905.img" it's the same result as any other ROM - When I'm turning on the WIFI or BlueTooth, it will turn off I wrote her back that I wanted to try another ROM if she could get one from the manufacture that's NOT AP6210 but a realtek
Yeah yours is clearly not med tek but realtek
I would make a request the D33 kernel thread to see if he can imake akernel with the driver for your wifi/bluetooth.
And the question: Which of the kernels from the link beneath the D33 from the link you provided earlier on? Is it just the RLT8188EU ? And when I download the kernel, what do I do with it?
It looks like he only made tv stick kernels in that verions for 3.1a.
You can put in a request to have him make a newer 4.1 with it but for the moment 3.1a should still work as nearly all the roms up here are still based on beta .
Okay So the RTL8188EU will be a try! Do I need to delete files from the old build or do I just paste the new kernel in the ROM folder? (Im all new to this tv-stick thing!)
Yes is the simple answer - but don't blame us if you blow it up
You just have to tell the flash tool what kernel you want if I am reading your intentions correctly.
Let us know how you get on.
4shared is a perfect place to store your pictures, documents, videos and files, so you can share them with friends, family, and the world. Claim your free 15GB now!
Patrickpetersen...did you finally solve the issue?
I have just purchased one of mk809iv...(29usd on aliexpress shipped)
And i am collecting the info prior to receive it.
Which ROMS are usable?
Is announced a kitkat out there...is usable?
Can you provide links for valid roms?
Many thanks in advance
I have that same one, and mine both chips say MEDIATEK on them. Are you saying yours have both MEDIATEK and REALTEK chipsets?
EDIT: NVM, I didn't read the msg you saying the first pics weren't form your device.
Usually AP6210 has a silver cover and it says AP6210 on it - AND the antenna cable is attached to the cover and not the RED antenna
Mediatek has 2 chips on the board/module and both say MEDIATEK on them
and Realtek has a single chip on the board/module and both of these have the antenna cable attached to the RED antenna, which BTW I found it useless, it dropped 1 bar when I pulled it out.... LOL
