Alas it is not going well due to NO KERNEL SOURCES!!!
I believe I will never be 100% successful without a new 10G2 ICS kernel
However I did manage to get it to boot so you can have a look at what the Arnova 10B G3 ICS looks like on your 10G2. I used a ICS kernel that does work (telecast T760) but some stuff DOES NOT WORK.
No touch screen (you need a USB mouse to use this)
No WIfi
No sound
But for those that like to play around and have a look see, this is a PREVIEW ROM of what ICS will look like if I ever get it working fully. If I could find ICS .ko drivers for the 10G2 screen (hardware) I believe I can get this to work!
NOTE: YOU WILL NEED A USB MOUSE TO NAVIGATE THE TABLET!
Anyway, if you want a look see to how ICS works, here is the ROM I have made so far. I have to say it works pretty well and is not slow!
ROM -> Arnova 10 G2 - ICS "Preview" ROM (142 megs)
P.S. For those that have my 2.1 ROM with CWM and have made a CWM backup to SD card. After playing with this ICS ROM you do not have to flash back fully!
Simply open the 2.1 ROM kit and flash ONLY the following:
boot.img, misc.img, recovery.img, kernel.img, parameter.img
This will flash super fast (seconds)!
Then just use CWM to restore and you will have your tablet back to normal in minutes!
Damo - Forum Moderator
PLEASE CLICK THE DONATE LINK BELOW
