PMID701i Screen Cracked
There are options, but most are expensive
See here:
So far most of the digitizers I have found have gone for $30-$45, I did see a combo digitizer and screen that was up arround $60 on alibaba, but you will likely wait for some time before it gets to you.
The other thing you need to be concerned with is that since you have the PMID701I there are 3 different versions and I think the screen and digitizer in each one is different too.
There are currently 3221 users online. 2 members and 3219 guests.
