Onda V979m, the sister of onda v975m, also powered by Amlogic M802 quad core Cortex A9 28nm process technology CPU speed up at 2.0GHZ and with Mali 450 MP4 octa core GPU. With 2GB of DDR3 RAM 32GB ROM.
Onda V979M tablet has a 9.7 inch Capacitive multi touch 2048 x 1536 pixels Retina display. The IPS display that support a 10-point touch capability. It’s not only can handle 720p video content, but also you can watch your favorite 1080p HD video playback without need to connect external display.
Onda V979M comes with an aluminum material and combined with stylish white front bezel and golden design on the back cover. Like onda v975m, the V979M tablet has dimension in 242.5 x 185.5 x 8.3mm and weighing around at 560 grams. The 8500mAh Li-ion battery claimed will gives more than seven hours of battery runtime between charges.
The 32GB of internal storage that backed by TF card slot that supports up to 32GB card for memory expansion provides plenty of multimedia storage space. You can install more applications and store all your favorite video without need to upload on cloud drive service.On the back cover, you will find a 5.0 megapixel rear camera with auto focus support for 720p video recording and captures photo. On the other side, there is a 2.0 megapixel front facing camera for self portraits and video chats, thanks to internal microphone.
The rest of features are internal stereo speaker, 3.5mm headphone jack, micro USB 2.0 port, mini HDMI port as HDTV connector, multi language supports, Adobe Flash, Android Market support, WiFi 802.11 b/g/n for rich internet browsing and more.
Source from: http://blog.geekbuying.com/
