I know we have to change the build.prop line ro.sf.hwrotation from 270 to 0. But when i do that with the stock rom i can only see a part of the screen.
[Q] Minix NEO x7 portrait mode
Originally posted by phohtoo View PostCould you please share the solution if it is solved. Thanks.
If you flash the finless rom for the NEO X7 (which is rooted by default), and you change the build.prop line "ro.sf.hwrotation" from 270 (default value) to 0 or 180 you will have a portrait orientation for the Minix device. (You will have to reboot)
There are currently 2505 users online. 0 members and 2505 guests.
