Is it bricked? Is there any way to recover?
808B... Bricked? Need help.
So i received my MK808B today and tried to flash Finless 2.1. I hit erase NAND like it said, that worked fine, then i hit flash rom, and that worked fine.. after that nothing happened and now when i try to get into recovery mode using the button all it says is USB has malfunctioned... I have tried 2 computers with the same result...
Is it bricked? Is there any way to recover?Tags: None
Originally posted by mherder View PostSo i received my MK808B today and tried to flash Finless 2.1. I hit erase NAND like it said, that worked fine, then i hit flash rom, and that worked fine.. after that nothing happened and now when i try to get into recovery mode using the button all it says is USB has malfunctioned... I have tried 2 computers with the same result...
Sorry it's not rk3188 chip in it and i can't see a lewy20041 hfw firmware for it try another firmware that includes a different updated flash tool use a current hybrid firmware with newer tool to see if it makes a repair? If your using the latest tool erase with an older tool and reflash with a newer tool and alternate firmware see if that makes good anything,very best of luck to you anyway.What is the world if you don't explore?
Originally posted by mherder View PostIt was running whatever OS it came with and i tried to flash 2.1 finless.
I agree 100% with PHYSC. The Finless ROM package should include this folder: "alternate_reboot_to_flash_tool". Open that folder, and right-click RKBatchTool.exe and select Run as administrator. If you have a device with original hardware (non-clone), then the latest firmware (in .img format) seems to be this one: http://pan.baidu.com/s/1bnF2tIJ though I have not tried that one yet myself. If you prefer to use the last version posted to Geekbuying's blog, here it is: http://blog.geekbuying.com/index.php...ore-tv-sticks/
The [...] button next to FW Path section is the button to press to load the .img file. I believe "Restore" is the flash button.
Originally posted by mherder View PostMy computers are running windows 8.1
I've been resorting to finding an Win 7 PC each time I need to flash.
Also, forgot to mention --- the stock ROM that I linked to is 720p output. Even for 720p, the power adapter that came in the MK808B package SUCKS. I use either my TV's built-in USB port to power the device (most people don't recommend this) or a 2.1a usb hub. From ididmytime's old FAQ:
Q: I keep getting freezes, my device keeps crashing.
A: The first step to take for any issues like these is to change the power supply. They are not all made equal, and some can't give the device what it requires to run stable. Any decent 2amp 5v charger should be more than enough.
There are currently 1804 users online. 0 members and 1804 guests.
