[CUSTOM ROM] [MK902] QUICKSHOT v3 by THe NiTRo TeaM
    Re: [CUSTOM ROM] [MK902] QUICKSHOT v3 by THe NiTRo TeaM
    Originally posted by scooter2014 View Post
    MK902- TESTS
    Ok did further testing and got xbmc to load crashed in movie, beyond loaded crashed then crashed 3 times longest run was 20 minutes without reeboot or freeze, let me know what logs you want as 4 boxes loaded with it now but not one will stay running. files open access and had crash in that as well, Has anyone on a MMK902 got this rom to load and not crash or re boot?? ( on windows 8 machine ill have xp machine tonight so ill re flash with that system tonight as i still dont trust these fricking drivers from rockcrap!)
    it's not rebooting nor freezing on ours. There's just one of ours having this behavior and we think it's a faulty device because it does this on every rom not just qs3.
    Please try a lower speed kernel, maybe it's just a matter of too much OC for cpu or ram. not all devices support the same OC values.
    Regards
    There are 10 types of people in the world: Those who understand binary, and those who don't...
    If you want to buy me a beer, please use this -> https://www.paypalobjects.com/en_US/..._donate_SM.gif
      Regards
      Its loaded on 4 boxes and same on all 4, ill switch computers and re load them again tonight they all boot fine with d33 kernel and neomode,smic roms. all those are oc to 1.7 no issues so maybe new windows machine issue so ill switch back to my xp machine tonight never had an issue with it before.
      Thanks Leolas
        Thanks Leolas
        Thanks to all the team, we made this ROM all together
        Leolas
        Sent by my phone.
        Enviado desde el telefono.
        My devices:
        Gearbest.com)
          24 HZ Display option
          Hi all,
          First of all, thanks for the rom leolas, it looks amazing!
          Just one question, is there any way to add a 1080@24 hz option ?
          Maybe I could flash another kernel with this display option?
          I have quite media files that need this resolution for be reproduced smoothly....
          Thanks in advance!!
            Originally posted by oscarguti69 View Post
            Hi all,
            Thanks in advance!!
            In our next fix we will provide new kernels with this option.
            Leolas
            Sent by my phone.
            My devices:
            Gearbest.com)
              Just to test stability, I decided to flash the stick on my lapdock with this ROM, since that's the one I use all the time. To be clear, I flashed this ROM on an MK809III with RK3188T.
              I've run it for 3 hours, used bit torrent to download movies to my SD CARD, transferred files to/from my NAS, played XBMC - and used a USB sound card to listen via headphones. Everything worked great, perfect stability - no unexpected shutdowns like I occasionally saw with Neomode 1.9A. The only thing I could wish for would be a sound fix for screens that don't report back.
              Speaking of which - Leolas, did you get the dmesg I sent you via PM?
              On a different note, I tried to flash this rom on a different MK809III with a full RK3188 (not T) - and it wouldn't even boot. I got weird lines on my screen, occasionally flashing. I flashed back to Neomode 1.9A successfully. I'll try again tonight, but it's funny - I never thought I'd wish this stick were an RK3188T. :-)
                Hello everyone. Thanks for this development.
                I've been trying this for a couple of days and i have found an issue.
                When it starts the screen is not scaled correctly, the clock stays a bit out of the screen. I have it connected thru HDMI to a normal Sony HDMI 720p capable screen.
                Every time i have to go to settings and scale image. And the best part is that just when i hit the button the screen scales correctly. But the option never gets saved and i have to do it everytime.
                Another completly different question. What is the root ssh password? i tried to change root password with passwd but seems that this command doesnt exists on android.
                BTW the video playback is so smooth, congratulations.
                  Ive flashed on 4 different boxes and not one stable cant get them to run more the 20 minutes but they run smic rom at 1.8 and d33 kernel, Neomodes also runs same but more stable at 1.7 cant figger out why this one is so problematic on all 4 Mk902?
                    Thanks, the scale issue is resolved in the update that we will publish soon. I cant help with ssh pass sorry.
                    Sorry we tested the rom in 3 devices before publish it, and all of them works stable. Try to use the cpu1400Mhz kernels included in the kernels-pack. Anyway we will release a update 3.1 very soon. I wish youo better luck wiith this one.
                    leolas
                    My devices:
                    Gearbest.com)
                      Ok ill try again once new release out, boxes get warm fast, i can keep stable at your set rom but only if cooled externally? is the kernel d33 build? as the one he made runs fast at 1.4 and cool at 1.8 ? so its seems the boxes resetting because of heat issues, nothing else.
                      we just tested with new shipment same results, none run longer then 20 minutes, but the one box on fan still going so thats 8 boxes tested, none work without cooling.
                        Unless someone knows a good reason not to, Im going to attempt flashing this on my MK802IV and test each of D33's last two 3188 kernels with it tonight.
                        Sent from my SGH-I337M using Tapatalk
                        EDIT: no luck just flashing the QS3 ROM. Tried three times. First startup gave me an error stating the external SD couldn't be mounted, then it indicated it was clearing cache and would reboot. The auto restart gave no signal to TV. The next two flash attempts yielded no HDMI signal at all.
                        Please post your h/w & s/w as signature to help community with troubleshooting problems.
                        Mk802IV / AP6210 (RK3188) - SMIC717394 809III 1080p 4.4 (v2) base & default kernel w/ 4gb parameter.
                        uTechsmart (Asix AX88772 chip) USB Ethernet Adapter
                        iLuv iAD517 2.1A USB PS + Asus AD83531 2.0A USB PS
                        Motorola 89451N BT KB + Logitech K400r 2.4GHz KB
                          leolas
                          debuti, ya te he encontrado en el foro de androidpc.es. Cual es el foro bueno?
                          Un saludo.
                          translation: already found you on another forum, which one do you visit more?
                            Sorry a lot, but we don't have a mk802IV device. The kernel must be different.
                            Un saludo.
                            Both are good, this in English and the other one in spanish
                            sent by my phone.
                            enviado desde mi teléfono.
                            leolas
                            My devices:
                            Gearbest.com)
                              Leolas: No worries. It was a long shot anyway. KitKat will happen to my stick eventually. I'm lucky to have a factory "recovery" image and then Neomode's NCR 1.9a to fall back on.
                              Cheers! Keep up the good work.
                              (EDIT: It should be noted that i didnt attempt flashing D33's kernel when I dropped QS3 on my stick. With more time and patience, possibly with another kernel, it may have worked. Magnus33 somehow made it through boot, and he has a -T chip in his 802IV stick.)
                                This ROM is working remarkably well on my MK 809III with RK 3188T processor. It won't install on the same device with a full RK3188, which is ironic.
                                This is my favorite rom/TV stick combination yet.
