Multichannel AAC on S802 - does it work?
I have ordered a couple of vegas and are on their way. I see that XBMC final gotham plays movies with Dolby (AC3) and DTS just fine. What about movies that have mutichannel AAC? There is an option in XBMC that enables transcoding from AAC to Dolby Digital that is passed to the optical output for amplifiers. Has anyone tried this?
ThanksTags: None
Originally posted by vprasinos View PostI have ordered a couple of vegas and are on their way. I see that XBMC final gotham plays movies with Dolby (AC3) and DTS just fine. What about movies that have mutichannel AAC? There is an option in XBMC that enables transcoding from AAC to Dolby Digital that is passed to the optical output for amplifiers. Has anyone tried this?
Can you share me the movie?Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
All new movies that can be downloaded from known sources (eg p*rat****) are shared in multichannel aac. Takes less space and quality is the same. It is actually becoming quite common in recent releases. Go to p*rat**** and make a search for eg. 720p x264 aac. You'll get a lot of results with 6 channel aac.
This has to be converted to dolby digital for the amps to understand as there is no amp that does aac decoding. You can download a few (or the ones I have below) and let me know if the audio gets automatically downmixed to stereo or if enabling transcoding works acceptably... (many slower devices running xbmc like the raspberry pi cannot do this efficiently)
Examples to try: this or this
Sent from my SM-P600 using TapatalkLast edited by vprasinos; 17 May 2014, 09:02.
I am having the same problem. AAC 5.1 files are played in 2.0. I have read on the XBMC forum that XBMC should do the transcoding from AAC 5.1 to AC3 5.1. One poster on that forum stated that XBMC Gotham has a "Enable Transcoding to AC3" (or something close to that) setting just under the "AC3 Capable Receiver" setting. There is no such setting on my setup. (With 'Expert' selected) I am not sure if the XBMC that Geekbuying provided with the Vega S89 is a "standard" Gotham.
Originally posted by 4WheelSpyder View PostI am having the same problem. AAC 5.1 files are played in 2.0. I have read on the XBMC forum that XBMC should do the transcoding from AAC 5.1 to AC3 5.1. One poster on that forum stated that XBMC Gotham has a "Enable Transcoding to AC3" (or something close to that) setting just under the "AC3 Capable Receiver" setting. There is no such setting on my setup. (With 'Expert' selected) I am not sure if the XBMC that Geekbuying provided with the Vega S89 is a "standard" Gotham.
Originally posted by zoelechat View PostThis option to transcode to AC3 exists at least in XBMC 14.0+ nightlies...
Originally posted by 4WheelSpyder View PostThanks for the response. The XBMC provided by Geekbuying needs root access to sort some of the problems and I was not sure if it was modified specifically for the s89, that is why I was hesitant to try any other. Have you tried 14.0+ on a s89?)
oman's version
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by zoelechat View PostYes, I'm always trying to use latest Nightly, I encountered no problems for now but I'm almost sure root is also needed to prevent potential A/V sync issues (I'm rooted and I see no reason not to be)
PS WOW, this must be the most active forum for any android device.
Originally posted by no_spam_for_me View Postoman's version
http://www.freaktab.com/showthread.p...-s802-platform
Got it - thanks!
Originally posted by 4WheelSpyder View PostThe secret is to set the number of channels to 2.0. As soon as it is set > 2.0 the option to transcode goes away and only 2.0 is output - kind of counter intuitive but it works!
(stable ARM Gotham version I'm using now, not specifically Tronsmart one)
There are currently 2704 users online. 2 members and 2702 guests.
