I have a Q7 book which is working fairly well. Its running 4.2.2. I have been asked to get two similar boxes for a friend but would like to know who to copy the the ROM and all the apps on my device so that I can copy them over onto the new device. I would particularly like to copy the xmbc and all the setting I have on my currently box thus saving me having to install fusion and all repositories again. Any advice would be most appreciated.
Backup and copy to another device
I have a Q7 book which is working fairly well. Its running 4.2.2. I have been asked to get two similar boxes for a friend but would like to know who to copy the the ROM and all the apps on my device so that I can copy them over onto the new device. I would particularly like to copy the xmbc and all the setting I have on my currently box thus saving me having to install fusion and all repositories again. Any advice would be most appreciated.Tags: None
open es file manager, make sure you can view hidden files
go to "Android" folder then "data" folder then ".files" folder
then finally copy the "org.xbmc.com" folder to your USB storage key/external sd card
Install xbmc on your friends android device run it atleast once.
Finally copy the folder you copied to you friends android device at the same location of course
Have a look at my sig...
That's the way to clone the device...
If you only want to copy the app's and settings, use titanium backup...
But need root
RK3288 Devices
- Overview BOX (LINK !)
You can install it from xbmc, program addons.
There are currently 4182 users online. 1 members and 4181 guests.
