Get lost at CS918 ROM !! LAN can not work by every ROM I tried !
    Dear All,
    I am new one for CS918. did not backup my CS918 original ROM, the original one LAN is working.
    I check the possible HW is ( not seeing any printed number on board, just check the chip set )
    T-R42 / CS918BT => PCB: B351_V1.0 (guess ) => WLAN: AP6210 (true) + LAN: asix ax88772 ( LAN is no mark )
    I flash Wasser's T-R42 old ROM 1.2.4 got a stable running, but still can not make my LAN working, try other ROM, almost
    the same cases, Wifi and bluetooth is fine, always LAN can not be enable, the LED shown at my Switch is on, however,
    DHCP, Static IP can not work, it just return to disable around 5 seconds enable.
    Any suggested ROM to let me get back my LAN connection ?
    Dlai
    Got a ROM can let my CS918 working by LAN, and everything seems OK, still trying
    Got a ROM can let my CS918 working by LAN, but support 720p only
    http://www.bee-link.com/goods.php?id=52
    also provide a 4.4.2 ROM, will try it.
