That is NO FLASH TOOL needed to flash a complete ROM on the S89!
It has been converted to ZIP format you can update from SDcard.
This is completely STOCK. No root or anything.
You Windows 8.1 folks that cant get drivers install should now be happy!
I kind of hate the flash tool anyway and should really only be used to unbrick!
Note: Unlike before, this time I am giving you the "Standard" ROM and a patcher for the Elite.
The ROMs between the Elite and Standard are the same except for wifi, and BT drivers.
So for Elite version, I am supplying a patch_2_elite102k4.zip.
If you have an Elite, after flashing the ROM, then also flash the patch_2_elite102k4.zip.
If you don't you wont have working wifi!
__________________________________
Download and unzip the file. Instructions are inside in the README.TXT
Here are the download links.
ROM -> S82/S89 - 102K4 Stock ROM -Standard & Elite - (400 megs)
Enjoy,
