iFive Mini3 Retina MIUI ROM Beta
    iFive Mini3 Retina MIUI ROM Beta 1Gb for Apps: http://pan.baidu.com/s/1o6wOWcy
    iFive Mini3 Retina MIUI ROM Beta 4Gb for Apps (bich0azul mod): https://mega.co.nz/#!aUVkmIyD!TI95oR...wbNjxjGaIIcwWk
    CWM Recovery from arctools or TWRP Recovery: https://mega.co.nz/#!HMcEhZQA!XDq3Jw...ZOxaKWCE1nG3WQ
    GAPPS
    : http://www.androidfilehost.com/?fid=23311191640114013
    Review: http://www.5fans.com.cn/thread-126205-1-1.html
    very nice, thank you,
    where can I find the GApps for the tablet?
      Re: iFive Mini3 Retina MIUI ROM Beta
      Here... you need flash them with recovery... no wipes...
      Download GApps, Roms, Kernels, Themes, Firmware, and more. Free file hosting for all Android developers.
      Enjoy...
      Enviado desde mi rk3188 mediante Tapatalk
        Enjoy...
        But Miui is not rooted, I can t reboot to recovery mode
          You can root it with kingoroot... http://www.kingoapp.com/
          And flash the TWRP recovery for ifive mini3... http://www.freaktab.com/showthread.p...l=1#post156414
            If you flash TWRP and enter it on exit it will ask if you want to root your device.
            Tapatalked
            if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
            then mv $user.contact.up.post /.trash; set response($response.type = ignore);
            $user.up.post.ignore_in_future = true; fi;
              root OK
              but after flash the TWRP nothing change
              edit
              2. You have a recovery.img file in folder recovery
              Appuyez sur une touche pour continuer...
              * daemon not running. starting it now on port 5037 *
              * daemon started successfully *
              device
              Pushing files
              2000 KB/s (14925824 bytes in 7.285s)
              1910 KB/s (885236 bytes in 0.452s)
              Flashing
              /system/bin/sh: /system/bin/sh: - : unknown option
              Disabling install-recovery.sh
              Cleaning
              All done
              Don't forget to give feedback
              Bye bye
                Tapatalked
                Thanks for the tip... and thanks for the TWRP ports...
                  thank you to
                    Updated first post
                      Hello to all friends,
                      I tried to install the miui in my ifive.
                      I was not able to have root with kingoroot.
                      I installed the TWRP's with Rockchip flashing tool but I do not know how to boot into recovery (such as keys used).
                        To boot into recovery, for example, use https://play.google.com/store/apps/d...ions.quickboot
                          Thank you,
                          what do you recommend for the root.
                          I tried but I did not recognize the device.
                          you have root with kingoroot?
                            I do not install it yet. I do not know.
                              wow, cool to have miui on ifive as well (i love it on my xiaomi hongmi). is there any way to install this on a non-retina device, or would you advise against even trying it? if so, any idea how hard it would be to adapt this to a non-retina ifive mini 3?
