Help me with Tronsmart s89
    Hi to everybody
    I am new at the forum and I have a problem with my s89. I installed the custom 1.2 on my s89. I restart it because xbmc didn't work and now I can only see the desktop and a message that say "you can only ring emergency number". Is there someone that can help me with that?
    Bruno
    [QUOTE=Ulrbru;180700]Hi to everybody
    Bruno[/
    I solved the problem. I forgot to I had a password. I just prompt it and now it works. I removed it now.
    thanks
    Bruno
