replacing boot.img Amlogic M8 (questions) (custom boot.img)
    I have a few questions regarding replacing the .rle files when the boot.img is unpacked.
    I plan on creating a custom boot.img
    When I unpack the boot.img i see 3 .rle files... firstinitlogo.rle , initlogo.720p.rle , initlogo.1080p.rle
    My questions:
    1. Does the firstinitlogo.rle file need to be replaced?
    2. What is the resolution of the firstinitlogo.rle file? I need to know the resolution, so i can replace it with the exact same resolution
    Code:
    firstinitlogo.rle
    https://drive.google.com/file/d/0B7mM_AqFt1qQLVlHenZKUFpnWVE/edit?usp=sharing
    if you want to change the initial boot logo pls refer here:
      feh
      thanks button +1
