I have a PMID702C, which I recently got Google Play installed and working (yay!!). Its been working fine, but now I get a msg that "0 possible sd cards found", and when i try to download anything, it says they fail. Also been trying to use Evernote, and that app says it cant create a database.
I also have DroidTV installed, and I can't download any new episodes because it says SD card size exceeded. I looked at the sdcard folder in root explorer, and it reports 763 mb available, and it is mounted as RW. I recently deleted everything off the EXTSD card because i thought it was looking for room there but that was not it. the EXTSD I pulled from another tablet, so there was nothing on it I needed.
Apps from Google Play download and install fine, but they don't from the Amazon App Store (download failed). Also, when i go to try the camera, it says "please install an sd card first". The error I get when I try to use evernote is:
"Database Read/Write error
Evernote is not able to create the database file. If the problem persists then please restart your phone and make sure that the sdcard is not full.
android.database.sqlite.SQLiteCantOpenDatabaseExce ption:unable to open database file"
I REALLY do not want to reset this tablet as I have Google Play finally working, so can anyone give me some idea as to this problem?
Thank you.
