Nextbook Premium 7 Flash issue.
When playing flash videos, the frame rate was under 10 frames a second on a yf0911 Nextbook running the Finless 0911 1.4 mod. It was the same running the Nextbook gingerbread ROM. I installed the 10.3 hulu modified 10.3 flash apk., uninstalled it and installed flash 10.3. Videos then played in the Dolphin HD browser at a normal frame rate. However, every time I powered down the tablet, I had to reinstall 10.3 Flash for it to work. I then installed the original Flash 11 that came with the Nextbook ROM and I still got a full frame rate, but I still have to reinstall flash every time I power on the tablet. Does anyone know how to resolve this issue? Thanks. ChuckTags: None
Originally posted by chuck3565 View PostWhen playing flash videos, the frame rate was under 10 frames a second on a yf0911 Nextbook running the Finless 0911 1.4 mod. It was the same running the Nextbook gingerbread ROM. I installed the 10.3 hulu modified 10.3 flash apk., uninstalled it and installed flash 10.3. Videos then played in the Dolphin HD browser at a normal frame rate. However, every time I powered down the tablet, I had to reinstall 10.3 Flash for it to work. I then installed the original Flash 11 that came with the Nextbook ROM and I still got a full frame rate, but I still have to reinstall flash every time I power on the tablet. Does anyone know how to resolve this issue? Thanks. Chuck
Make sure you set all the permissions for the apk
Than reboot. This will make it a system app. Or if you have titanium pro you can convert the program to a system app
Sent from Xperia Mini Pro ~ Android 4.0.4 ICSPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Originally posted by Damo View PostIf your tablet is rooted than you can place the flash.apk into system/app
Have you gone into the browser settings and turned it on? Most browsers have it off so you have to click on the giant arrow in the flash box on the web page to start it. Some browsers allow you to go into browser settings and tell it to play on load.
If the browser you using doesnt have that then try another one. I like Opera (not opera mini). Dolphin browser is also good.
Originally posted by Finless View PostHave you gone into the browser settings and turned it on? Most browsers have it off so you have to click on the giant arrow in the flash box on the web page to start it. Some browsers allow you to go into browser settings and tell it to play on load.
Yes, I have flash turned on in all browsers and it works well after I reinstall it. It doesn't work after a shut down and turn on in any browser. I use Dolphin HD because it is the only browser where I get an acceptable frame rate. Thanks. Chuck
There are currently 5389 users online. 4 members and 5385 guests.
