Running Finless 1.8 rom. Switched HDMI,rebooted and the same.
Green squares
Originally posted by roughie3 View PostAnyone else had an issue where any video plays with green flashing squares in the background?
here:
---->>> http://minixforums.com/threads/neo-x7-009-firmware-24-jan-2014.3898/page-6#post-36336
look if u find your answer there
there some people discussed videoartifacts and videoerrors
also an discussion here:
--->>> http://forum.xda-developers.com/showpost.php?p=49633857&postcount=404
and here:
---->>> http://forums.whirlpool.net.au/forum-replies.cfm?r=40436985#r40436985
this one looks also very good:
-->>>>>http://www.xbmchub.com/forums/thread...th-some-videos
aaaaand finally there:
---->>>http://forum.xbmc.org/showthread.php...68268&page=103
just look for "artifacts" in every posting ;D
i hope it will help you ^^
if you cant find any solution looking into these postings -->> we are there 4 you ^^
maybe someone here have a solution
and for the future -->>>
and here:
Mine is doing it in the settings menu as well and not just in video. They squares are static until I changed and they move down a line. Nothing has changed, no updates and no new apps. Really weird.
Originally posted by roughie3 View PostCheers for these. had googled but didn't know the specific term
maybe cable is defective,or bad quality (happens often,reaaly often ^^) or the contact is not perfect to the tv.
try to sort out these errors
if nothing helps -> reflash and do a full wipe of the system (erase nand ....)
just search for "erase nand" in this forum and u will find it, it hink in "quckshors v3" thread or "wassers kitkat" thread u will find a way to clean the system completely.
Open RKAndroidTool.exe and click ERASE IDB, when the process of NAND erase is complete, click Run and this flashed the new ROM, after which the Stick will restart automatically. Initially entering the stock recovery and formatted some internal partitions. Then it will restart again and begin the startup of the new ROM.Last edited by dermuggi; 22 May 2014, 08:33.
-->> quickshot v3,first posting ;D
i have foound new conclusions
-->> http://androidforums.com/samsung-gal...ss-screen.html
and if you want to search inside google pls use this
--->>>https://www.google.de/search?q=green+squares+android+flickering
It's not the top one,as it's my TV. Also, it seems to be certain backgrounds that always cos it. Going to reflash today
Originally posted by roughie3 View PostFlashed with stock and still the same
There are currently 1599 users online. 1 members and 1598 guests.
