ip cam as webcam
    ip cam as webcam
    I have an ip cam I would like to use as a webcam on my X7 with Skype. can anyone recommend an app to do this? On Google play there are many apps to turn android phone in ip cam or view ip cam but Carnt find one to make ip cam recognised by skype as webcam.
    --------->>>http://www.instructables.com/id/How-to-use-an-Android-phone-as-a-webcam-with-Skype/?lang=de
    ------->>>https://www.google.de/search?q=p+cam+recognised+by+skype+as+webcam#q=p+c am+recognised+by+skype+as+webcam+android
    -------->>>http://www.cnet.de/41551281/ip-webcam-fuer-android-so-wird-das-smartphone-zur-webcam/
    --------->>>http://www.youtube.com/watch?v=KtDqfFSYp0E
    ---->>> http://www.giyf.com/
      Thanks for the links and the sarcasm, but next time you want to be sarcastic can I request you actually read the question.
      The first link you post I had read and refers to using windows and an android phone as the cam. (not what I'm asking)
      The second link, a Google search is about using an.android phone as ip cam! (not what I'm asking)
      Neither of these are what I'm trying to do. I have a dedicated ip cam! I don't need to use an old phone as the cam.
      What I need is an android app that will recognise the feed from the ip cam and make skype see it as a webcam. Non of your links explain this.
      So thanks but yes I do know how.to use Google, do you know how to read?
        and this one?
        name of the video "
        How to make an IP Webcam (Skype Compatible)"
        comment of the author "
        JackkTutorials shows you how to make an IP Camera using a Android Device"
        must be the perfect one 4 u oO
        if not,then iam sry and i will try to find another solution -> with google ^^
        edit: try this one,maybe helps -->> http://community.skype.com/t5/Window...s/td-p/1427523
        also looks good: --->>http://askubuntu.com/questions/52856...am-as-a-webcam
        its for ubuntu but maybe there u can see the right way to the solution
        also try this one -->> http://games.reveur.de/board/showthread.php?tid=7667
          Lol last time I checked the x7 runs android which as it happens will not run Windows software! Read my question again and watch the video you posted!
          Again I want to use Skype on my android neo x7 to connect to an ip cam.
          I do not want to use my android phone's camera to connect to Skype on a WINDOWS PC. As all the links you are posting tell me how to do. The key here is ANDROID not WINDOWS!!!!!
            Your second link
            "I have a network video stream (mjpeg) from an android phone that acts as an ip webcam and I would like to use it as an actual webcam on my PC(for google talk, skype etc.)"
            An X7 is android it is not a pc!! Clear?
              And your third link
              Translated to English, thanks Google
              "The mobile phone is connected via USB. , the necessary software "IP Camera Adapter" I've already installed. When I type in the IP of the (launched by the app) server in the address bar in the browser I get on the page with instructions ( Word document DL ), which I have followed. If I then open Skype and go into the video settings, Skype apparently recognizes that there somehow a camera on the PC hangs, it just hangs immediately on."
              Again android phone on a PC, are you grasping this yet? X7=Android pc=windows.
              If your going to try and be a smart ass with someone asking a sensible question on an Internet forum at least read the question properly and get your facts straight.
              Ok?
                And your third link
                Ok?
                i know that maybe all solutions are directing to PC but right now i cant find any solution for android but there are sometimes ways to use linuxsoftware on android.
                i just want to show you stuff where you maybe can find something that could help you
                the RIGHT way or solution has to be found by ourself but ill search a little bit more.
                can you tell me the model of your ipcam ??
                  find another thread
                  and yes,its for pc,but i think it shows you the way how it will work:
                  --->>>> http://www.computerbase.de/forum/sho...42#post5348142
                  we have to find the software mentioned in this posting,compatible to android,then we got a solution ^^
                  --->>written in delphi,i dont know if there is a way to use software written in delphi on android.
                  but this software maybe would do the trick
                  Download Link2Cam for free. Link2Cam is a PC application and a directshow pushsource filter, written in Delphi, that allows the use of Linksys IP Cameras with IM softwares such as Skype or MSN Messenger
                    Exactly why I was asking the question, I know what I need just carnt find an app to do it after many hours of searching on both google and google play. While I agree people need to find info for themselves sometimes many hours of endless searching can be saved with a simple question if someone has already done something similar, isnt that what we have forums for?
                    Cam is a Vstarcam T7838WIP, can access the feed from the X7 and view in browser just need the adapter app like the ones for windows PC to make it show in Skype as a webcam.
                      iw ill try my best :d - and sry for to be rude :C but many people are asking question already has beesn discussed 100 times in google and i hate it when these people AGAIN asking US the same question again.
                      as i now can see you are not one of these people ;D
                      so -> iam sry then
