NEW Stock firmware! - Onda V975M V2.0.1 Android 4.4.2 KitKat V1/V2 - V3/V4 ROM Download 2014-05-16+root
    [ROM] Onda V975M V2.0.1 Android 4.4.2 ROM
    ROM: 449M
    2014-05-16
    1. System Up to Android 4.4.2
    2. Optimize Power Display.
    3. Optimize CPU and RAM
    Onda_14.05.16_kit_kat_4_4_2 V3/V4 Download
    Onda_14.05.16_kit_kat_4_4_2 V1
    ONDA_V975m_Root_SU-1.93-A4.4fixed+root
    Apps You can remove the Chinese apps! Restart!
    Recommended Launcher!
    S Launcher
    Smart Launcher
    Nova Launcher
    Recommendations
      Originally posted by Sigismundpower View Post
      Definitely a matter of opinion.
      https://public.bay.livefilestore.com...ion.png?psid=1
        Onda V975M tablet speed up by 30% and energy saving!
        The processor is unable to drive properly on the screen. Therefore, the screen resolution and the change in the density leads to acceleration proceed!
        Opportunity! V975M
        Resolution Changer Pro Root needed!
        Aspect Ratio 4:3
        Width 1600 x Height 1200
        Density 200(225)
        Width 1440 x Height 1080
        Density 180(210)
        Only then check the Enable box! Root needed!
        Battery Doctor (Battery Saver) It only help!
        According to most of the testing for this device.
        If you do not use a 3G modem Aeroplane mode. Saves a lot of energy and when to use each.
          Onda V975M warming V3/V4
          The processor is adapted to resolve warming! The AnTuTu CPU Master Pro program to set all 1800 MHz! (only on Android 4.4)
            Hi Sig.
            Could you check the "root" link?
            esetleg priviben?
              litle help
              Email [email protected]
              Hi need a litte help if is possible i have a onda v975m ,but I,m not that good with firmarware update,i love my onda v975m can you just help me with the right firmaware,if I give the right info about my onda, I got confused with the version'don't know if is v1. Or v4.
              Baseband version. V1.1.0_v4
              Onda a9 core4
              Kernel version 3.10.10-01290
              Build number jss15j.20140328
              Sn:v975mbe4v4a42673
                v975m update help
                Hi i,m not that good with firmarware update,ilove my onda v975m can you just help me with the right firmaware,if I give the right info about my onda, I got confused with the version'don't know if is v1. Or v4.
                Onda a9 core4
                Sn:v975mbe4v4a42673
                  I have a ONDA A9 Core4 i think it is also known as ONDA v979.
                  How can i get a clean ROM for it?
                    V975m / V979m ROM = Model Amlogic M802 (ARMv7 architecture, Cortex-A9 x 4)
                    V975 / V979 ROM = AllWinner Model A31 (ARMv7 architecture, Cortex-A7 * 4)
                      ROM: 449M
                      2014-05-16
                      I canĀ“t access to any of the items.
