rk3066 need an apdate any help please
    hi there. im new this forum,
    i have a problem on my mini tv android dual -core A9 processor RK3066
    does any know something about it please cause when i insalled it on my tv it just showed up the logo android and then its gone and the screen stayed black.
    i need a new program for it ?
    thanks alot
    IS your TV 1090p or 720( Full HD or HD ready)?
    if the TV is 720p(HD ready), then you have to connect the device in a ful hd TV and change the resolution to 720p in the setting of the device..
      The tv is hd ready and its 1080p I use the ps3 on it too
        How I already said, if it's HD ready TV, then you have to correct the settings to 720p on the device...
        HD ready TVs can not display resolutions higher than 720p ...
        So you must find a full HD TV and connect the device to it, and correct the resolution...
          I put my tv on 720p and still the same after the logo android the display it comes black and I left it for 30mins running and it was still black. I changed the hdmi port 1 to 2 and still the same thing. What can I do more please
            Flash Finless 1.7C with the default 720p kernel. That kernel is pretty fast and you don't need anything special (extra cooling, over 2a psu).
              Yes you can do that what sleepyguy said, if the device you have is MK808/MK808b...
              If not you must find a rom image for you device
