How to connect android tv box to tv?
    this android tv box only has rj45 jack and no wifi. I have a router and verizon dsl at home with the 1 modem connected to main PC (no wifi). Anyway, how can i connect the android tv box to my tv? Thank you in advance.
    Most of the android tv box's ( mini pc ) have/use an hdmi cable to connect it to an HDTV... you didn't say which device or even which tv you have... so I can only answer generically
      If I understand correctly, you want to know how to connect to the internet with your existing setup. If so, you will need an Ethernet switch,and run an Ethernet cable to your Android box.
