Tronsmart Vega S89 reduced speed with wifi 2.4G. Why?
Hello to all of you especially our great Bob. On my s89 Tronsmart Standard finless 1.5 rom, I have a problem with wifi 2.4G because for the moment I do not have a router 5G, I have a very slow connection and sometimes No I can not see a video on youtube with Blutooth off .I point I also have a MK908 with the same settings to the S89 and the wifi gives me excellent results with various test adsl all goes well, I know I have with tronsmart S89 download of 4-5Mbs When MK908 with 26Mbs, on the 2.4ghz ,ask you all if it is only a problem or even my other holders of the S89. Thanks in advance .Last edited by Renixo; 24 May 2014, 14:58.Tags: None
Originally posted by Renixo View PostHello to all of you especially our great Bob. On my s89 Tronsmart Standard finless 1.5 rom, I have a problem with wifi 2.4G because for the moment I do not have a router 5G, I have a very slow connection and sometimes No I can not see a video on youtube. I point I also have a MK908 with the same settings to the S89 and the wifi gives me excellent results with various test adsl all goes well, I ask you all if it is only a problem or even my other holders of the S89. Thanks in advance .
Do you use a wireless keyboard/mouse with 2.4GHz dongle?
Try your WiFi without it and if the speed is higher, than try to use an USB extension cord and place the dongle far far away from the device...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostDo you use a wireless keyboard/mouse with 2.4GHz dongle?
Originally posted by isham.padron View PostHow does having bluetooth on slow down the wifi? I can't imagine that being true.
In theory, they should both channel hop when interference is detected (for example WiFi splits the above range into 14 channels) and find the best frequency, seems to not always work out though.
Ideally their behaviour needs to be controlled so for example Bluetooth is resticted to frequencies in the bottom half of the range and Wifi the top half on any one device with both radios turned on, but alas I do not hav the programming skills to make such a thing happen.
There are currently 2556 users online. 0 members and 2556 guests.
